DQG Tiny 4th 18650 xml-2 review
If you want long runtimes at max power, how about the Zebralight SC600w III HI
  • Build quality is superb both inside and out.
  • The light has no timed turbo stepdown.
  • Thermal stepdown is unnoticeable. The light will maintain near max brightness for the life of the battery.
  • Excellent output: over 1100 lumens
  • Wide flood, with excellent throw (19,000 lux)
  • Shorter than most other 1x18650 lights, which is important for pocket-carry. Still considerably larger than the DQG though.
  • Flawless build quality
  • Perfect tint
  • Great UI
In my opinion, the SC600w III HI is probably the best stock light I’ve ever owned. It’s so good that Vinh gave up on modifying one because none of his modifications made a significant difference on performance. About the only bad thing about Zebralights is they can’t be modded by most amateur modders.
people,which driver will be fit into this flashlight? 3amps are not enough for me.i want change it.thanks
about driver :slight_smile:
2000mA
Just look what they’re doing
it’s step down driver and 3th tiny
http://forum.fonarevka.ru/showthread.php?t=22959
But you need new bezel & bit process on a lathe head :slight_smile:
http://forum.fonarevka.ru/album.php?albumid=940
list this two pages
http://forum.fonarevka.ru/showthread.php?p=731180&highlight=�����#post731180
http://forum.fonarevka.ru/showpost.php?p=731443&postcount=151
Some more pictures over here in my DQG 4 triple mod thread:
DQG 4th 18650 tiny triple XPL Hi
Not sure exactly what size driver will fit in. It’s larger than 17mm. I think maybe 20mm.
HOWEVER… the biggest problems is that the original driver includes both the driver and emitter on the same board. This allows for the most compact light possible, but unfortunately doesn’t allow you to simply swap in a new driver. Any new driver you could buy won’t have the emitter on it, and there isn’t room to install a single-emitter star, the optic and a new separate driver board.
Essentially, if you want more power, the only option is to convert this light to a triple. The Carclo triple TIR optic is 7mm shallower than the stock TIR. This frees up enough space to mount a star in front of the driver.
Carclo + glass(1.7mm)
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15420
Maybe use somewhat thinner glass. On mine (1mm x 21.3mm glass) it screws down all the way.
But nice, how’s the driver section working out?
I’m reorder new glass (1mm)
Driver glued. I squeezed it with a screwdriver. But in the end broke the resistor R50.
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15196
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15201
I finally finished my flashlight.
All photos here Светодиодные фонари и световые приборы. Всё о светотехнике. - Альбом MSS: DQG Tiny 4th XML2 18650
LED https://www.fasttech.com/p/3505302
Glass http://aliexpress.com/item/New-flat-glass-watch-crystal-diameter-21-5mm-Thick-1mm/1097050471.html
MCPCB http://intl-outdoor.com/noctigon-3xp-advanced-triple-led-copper-mcpcb-2-pcs-p-763.html
TIR http://intl-outdoor.com/carclo-10507-triple-led-optic-lens-p-836.html
Serp,
That is a fantastic mod! Thanks for the great photos and especially the links to the parts you used!
I do not like only a small gap between the bezel and the housing
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15681
Wabi Sabi
That gap is only a small flaw in an excellent build, take the excellence, accept the small flaw… Great work…
I am still too chicken to do more than swap TIR’s in mine…
Nice job :+1:
What driver did you use?
I think your heatsink (is it thermal glue?) is a bit too thick. The top of your carclo sit’s a bit too high for the gap to close on the bezel. Does the carclo slide all the way down? I had to sand off the edges a bit.
Or maybe you can sand down the heatsink. Or the noctigon board a bit, but that is not really nice for the already limited heatsinking maybe.
Or place an (O-)ring to fill the gap.
I don’t know these nichia’s you used. Tint looks nice. Is it bright?
I’m looking to mod a second one with the new noctigon board with the small added pad for a locator led and high cri nichia’s. Someday :person_facepalming:
Worked out nice for you! It’s really my favourite small powerhouse.
Really nice job.
Hi :slight_smile:
Original. Wires are soldered in place of the LED. I removed the LED on the soldering station (hot air 240С)
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15303
No thermal glue, only termalpast.
Optics sits right on the edge. In addition, Im made a pit under it
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15683
triple rests on a support of aluminum desired thickness
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15304
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15253
Not bright. I’m like it :slight_smile:
It’s warm white led (2500-2700K)
0,01А-0,25А-1,05А - after change SMD resistor R35 for R50
Turbo 2,25А
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15254
i have had one for about 9 months
used normally
last week the switch broke off the circuit board
kind of a bad design
pushing the button strains the 4 solder joints every time you press
be prepared for it to not last forever
i emailed david, the creator, he seems sympathetic but does not offer help
so far
i can post a link to pictures of the break
wle
i used to be a fan of this light
but i have had one for about 9 months, normal use, and the switch just broke off the circuit board
this is a weak design
every time you press the button, it stresses 4 tiny solder joints holding the switch on the board
sooner or later it will fatigue and fall off
wle
Wle, that is good to know, on the III version, the switch is body mounted, and mine is still going strong. I use the IV version as a back up anyway.Thanks for the update!
body mounted might fix that problem, the IV has it on the circuit board, at the worst possible angle
i’m going to fix it with a switch made of 2 wires in the air, that the button can press together
wle
It looks like a drop or two of epoxy between the body and the switch would also solve the problem.
Mike
the force of pushing the button would then be held by the epoxy - IF it stuck and did not also get tweaked loose by button pressing…
wle
