Convoy L6... XHP70 Beast!
MIne shipped on the 19th. The tracking number still doesn’t work.
I dithered on the N2 5A (4000k) and now it’s out of stock and I feel sad.
I still haven’t decided if I will buy this one. I really want it but I also have the S70… And I don’t really have a use for it so it’s purely for collection.
Maybe I will sell the S70 to make room for the L6 :smiley:
Me too. Very nicely done.
Bob
I’ve been ready to put an order in for the L6 for a while, and I’ve been keeping up with this thread as much as possible. But I have a few questions that I haven’t found answers to yet.
Questions for you guys:
  1. Has anyone received a NW L6 and verified that a direct thermal path MCPCB comes stock?
  2. If I wanted to throw in a new driver (like a FET), what do you guys recommend that will still work with the side switch.
  3. Any word from Simon on a host yet?
Thanks guys
It’s a 30mm driver in the L6 so you have to make an adapter if you want to run one of RMM’s 26-20-17mm FETDD drivers. Any ways go to link and start at the Top drop down. :+1: Pick Turbo Timer (drop down) Unless your going with moppdrv? Firmware (drop down) Standard E-switch or Custom E-switch, or moppydrv. (I go Custom on Big Lights usually 4 Levels the standard I believe is 6 evenly spaced.) Then 2 cell+ (drop down) LDO w/o or with 6v LVP FET Driver - 22mm Adapter for 30mm to 26mm FETDD driver. 30x26x1mm copper sealing rings (hydraulic seals) Easy enough to do! http://www.ebay.com/sch/i.html?\_odkw=metric+copper+washers+sealing&\_osacat=0&\_from=R40&\_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xmetric+copper+hydraulic+sealing+rings.TRS0&\_nkw=metric+copper+hydraulic+sealing+rings&\_sacat=0 Shop by Category | eBay Some assembly and fitting required :smiley:
Thanks for the tips!!
KawiBoy1428, that’s one heck of a “how-to” bro. I appreciate it! You should start selling these things. I (for one) would definitely be a buyer :beer:
KawiBoy1428 is an artist. No doubt about it. Unfortunately on your question about the DTP board he is one of three test pilots that did not receive a stock L6 with a DTP board. Simon put a lot of effort into resolving that quickly and to my knowledge (per Simon) only three were shipped without a DTP board. One to me, one to Dale and one to KawiBoy.
Based on everything I know of Convoy and Simon’s work I can confidently say that your light will have a true DTP board. Bait-and-switch is something you will not see with Convoy. If you or anyone gets an L6 without a DTP MCPCB please let me know. :beer:
Myself, I agree. I’m still a “new guy” but I have learned to appreciate Convoy products. They keep getting better and better. Very dedicated and dependable company.
+1
Has me thinking about a 22mm MTN-MAX 1A-6A Buck Driver - 5V-18V
12v X 4 amps = 48 watts
A 4s L6 wouldn’t be so hard for me I will soon have two extensions and a 2X ring tube.
Not sure if a 6v/12v SinkPad and/or L6 is up for that much though.
Speaking of that mcpcb the good people of SinkPad sent me a gerber file.
Thanks for any help
4S 26500 L6 or a 4S 26650?
I’d have to go with the 4S 26500 just to help keep the length down as much as possible. Is this going to be using a XHP35-HI? I had been wondering what that led would do in these bigger lights.
The two Keeppower 26650 5200mAh, I had ordered from Banggod arrived today. I got the short version 69,5mm :slight_smile:
Do you have a link to these? I can’t find them. Thanks
Maybe these batteries?
Thank you. :+1: Those look like it. For some reason they do not show up when searching for Keeppower or 26650. BG search has let me down again.
That’s pretty impressive mace. You only need to add metal flanges on the head and it’ll be perfect melee weapon.
http://forum.banggood.com/forum-topic-169932.html ???
Seems BG is convinced these are the old ones…
