ENEDED
Put me down for 1 5C…
Do take note that this is not Olight. OTR has been around since 2014 if I am not wrong. Their flashlight build quality is good, but their product prices were relatively higher back then. Read RaceR86's review for X6M flashlight https://budgetlightforum.com/t/-/25997 if you are unfamilar with this brand.
If this GBGB is successful, I am sure vendor will definitely bring in more models later on.
I should receive the light in about a day time. Stay tuned.
Ooooohhhhh, goody, looking forward to your review freeme!
It does look like a good host at the least for a micro triple… If you take it apart, please measure inside the head dimensions if you could…
Thanks again for this…
I’ll take one with 5C tint.
A micro triple that would be smokin’ :+1:
OTR M3 has arrived! Glad I have chosen 5C!
We are waiting for your review
Will rush for it.
Teaser.
On The Road M3 original gift set packaging. Battery was shipped me separately to avoid delay. Our group buy price will not include battery or charger.
Quick Test:
1) Tailcap measurement:
Ultra low: 10mA
Low: 276mA
Medium: 600mA
High: 1.285A
Turbo: 2.23A
920lm did not happen as expected.
2) Parasitic drain: 7μmA
3) PWM (Pulse Wave Modulation) is present but not really visible in real world usage.
Bezel has notches for a spanner, and in the diagram of the body and the pics of the bare body show threads at the head end…
Freeme, any chance an 18350 would fit since it appears a bit wider/longer than the Olight S1?
Looks nice.
Could you check it’s mod-ablity? Check for threadlocker on bezel, accessible driver.
It would be disappointing for easy modding to have it a press in bezel. Not unworkable, as you said earlier, just harder. I nodded my S1 Ti following member X3’s guidance and a video from another member. I used the PVC pipe cutters, then found the rotary tubing cutters (looks like a C-clamp with rollers on one end, blade wheel on the other) works very well to when changing emitters again…
I do like the size of the S1, but if this thing is a little bigger, as it appears, then this will become a triple for me…
Put me down for one more 5C, come to think of it… Always need a backup…
M3 does not accept 18350. It is modeled closely as Olight S10. Bezel is not glued, and can be easily remove with a pair pliers. Reflector is screwed into the aluminium pill like Olight. Same as Olight, triple conversion will not be as direct as we hope for.
EE X5?
Too bad , I´m out then. I don´t want to add yet another battery type to my collection… seems like nice light though…
Driver easily removable?
I will leave the driver intact till I finish all my beam shots and measurements. From the back of the view, I suspect it adopts the same driver layout as Olight below. OTR M3 has stated integrated pill design in their description.
Credit: wet
Looking forward to your impression of the tint as all as the beam shots!
Hopefully it is clearer now.
i just measured my olight s15r and blf A6, both had moonlight modes of 3 mA and next level at 25 mA, so this one has a brighter ultra low then.
nice flowchart for the ui!
it always starts in ultralow when long-pressing, and you get access to turbo and strobe by double/triple clicking.
Beamshot photo please!
And compare it to a few of the lamp brightness to what you already know everyone. Thanks!
