It would be disappointing for easy modding to have it a press in bezel. Not unworkable, as you said earlier, just harder. I nodded my S1 Ti following member X3’s guidance and a video from another member. I used the PVC pipe cutters, then found the rotary tubing cutters (looks like a C-clamp with rollers on one end, blade wheel on the other) works very well to when changing emitters again…
I do like the size of the S1, but if this thing is a little bigger, as it appears, then this will become a triple for me…
Put me down for one more 5C, come to think of it… Always need a backup…
M3 does not accept 18350. It is modeled closely as Olight S10. Bezel is not glued, and can be easily remove with a pair pliers. Reflector is screwed into the aluminium pill like Olight. Same as Olight, triple conversion will not be as direct as we hope for.
I will leave the driver intact till I finish all my beam shots and measurements. From the back of the view, I suspect it adopts the same driver layout as Olight below. OTR M3 has stated integrated pill design in their description.
This is ultra low is 10mA. It is slightly brighter than moonlight but it still pretty useful in my opinion.
There is on time memory (<3s) for the four brightness level. It will only start from ultra low by default when memory is cleared. (e.g disconnect power from circuit - you remove and re-insert battery into flashlight).
I am not sure either… basically no PWM, good tint, good modes, magnet, decent clip. I am not sure why nobody is jumping in on this one. This is basically the cost of 3 emitters. Looks like the LED is easy to change, the UI looks pretty good. I think it will make a nice EDC. I wonder if it could be reamed out to take an 18350?
It could be that nobody recognizes the brand “On The Road”. I discovered this group buy when some asked on Reddit if this flashlight was an Olight clone, and then I did some google searching for it.
True, I did like that it is a little larger than an S1. We all like our S1’s, but a bit more size goes a long way and this one should be pretty sweet in size. Not to big, not to small…
I am hoping to figure a way to put a triple in this, just for fun of course, but if not, it looks like a standard 20mm optic will fit and provide options for floodier beams if that is what you like (I do).
Brand is less of a big thing if it is made well, I picked Thorfire by comparing them to a Convoy, did not do too shabby for my first C8, but that was because I knew what to look for from reading BLF before I made an account…
