Driver for XHP35 LD-51
LD(济南东城) as the most preferred driver manufacturer among forums,they have a lot of good drivers,such as LD-21,LD-29.
Now they realeased LD-51 for XHP35.
Dia:28mm
Height:less than 7mm
Uses TPS40210 chip. 8-14V default 1A, max 1.5A.
thermal resistor SMTed.
Hi Rey, any details for the driver such as price, input voltage, dimensions?
That’s cool! Yeah, more information of this driver is welcomed. :slight_smile:
And I start to think which light can take 28mm driver…
Only 1.5 amps?
LD-29S High Effeciency CREE MTG2 / XHP 50/70 Driver
Nice to see new drivers come out.
I found it on Taobao. 12$. Input: 2s 18650, 6-8.4V.
Size?
Dia:28mm
The LD-29S cannot power XHP 35, which requires 12V.
But yeah, 1.5A is too low. We need at least 5A (about 60W)!
Have anyone tried it yet?
I might have interest in one of these but cant find them for sale anywhere except on taobao and I dont speak chinees…
Or does anyone else know of a 12V boost driver like this one?
I’ve been wanting to try the LD-35 with this emitter. I wonder if someone could test it with 4S emitters. The info I can find on the boost IC seems to indicate it should work.
A 4S emitter setup would indeed work according to the specs.
I just wish the current would be a little bit higher, around 2A sounds perfect in combination with the XHP35. (around 2300 lumens, maybe 2500 lumens?)
Uses a pic mcu so likely adaptable for Attiny.
What happens if two boost drivers share the same load (in parallel)? I.E., Could two of these be wired to one LED to run it at 3A?
Also, right now I have a bunch of spare boost drivers that output over 2.5A per channel, and have 2-channel operation. It boosts 3S voltage to up around 20V/2.5A per channel. The problem the average person may find with this driver; it is 50mm diameter. :expressionless:
Hmmmm i could make your drivers work on a custom build i would have to build a light from scratch or maybe it would work in like a SRK style light. I am currently looking for a driver for my XHP35
Ah, I made a really dumb mathematical error once I looked at the wattage that sums up. It’s about 1.25A per channel, 2-channels. Not 2.5A per channel. Sorry. Those are rough numbers I figured out based on some efficiency fudge factors I made up and knowing input wattage. I’m still not sure that’s the exact numbers, but it should be relatively close. When I have a chance I will do a complete test to find the true values, as I know the drivers are capable of more power than they are running at.
Kaidomain have them at $10.xx
Input max for 2 cell (boost)
I like how its looks, Big MLCC everywhere :slight_smile:
10 bucks? Hang on,I can beat that.
