Im in for 2pcs
I’m in for two.
Updated.
The problem is will it fit inside my L2?
Not without modifications…
You have to make the driver cavity bigger.
At that price I’d pop for four. I can always unload any extras later.
what host will be good for such setup ?
Any host that can use a 28mm driver. And preferable a 2 cell host. A couple that I can think of right now are the small sun zy-t08 and courui d01, though they need some modding to get it working.
There aren’t many around that wont require some modding, afaik.
@Rufusbduck, are you happy with the modes? (2% - 25% - 100%, off time memory and thermal stepdown controll (which is build in in driver))
Put me down for two please I will find a host but I really want to use the L2
Put me down for 4 please
Updated.
I’ll take 2
I will take two.
Regards Xandre
I will take four.
Thanks
I’ll claim 4. So this allows one cell to push XHP 35 ?
Will this work with other LEDs ??
No 2 cells
I’ll take 2 please. Will see how it does in a Courui!
If it is a boost driver, is it boosting 2 cells up to 12 V ? Is XHP 35 a 12 V led ?
If so, I will have to rethink this.
Please add more info to OP for us non-techs.
Here it is, http://www.kaidomain.com/product/details.S025108 and yes the XHP35 is 12volt. I run mine at 16.8v at 2.5amps. Going to try 16.8v at 3 amps soon!
Updated.
@KawiBoy, how do you want to use the courui? 2s3p 18350’s? Or a special configuration?
I have been thinking to use the courui too but I cant figure out the battery config.
