Updated.
The problem is will it fit inside my L2?
Not without modifications…
You have to make the driver cavity bigger.
At that price I’d pop for four. I can always unload any extras later.
what host will be good for such setup ?
Any host that can use a 28mm driver. And preferable a 2 cell host. A couple that I can think of right now are the small sun zy-t08 and courui d01, though they need some modding to get it working.
There aren’t many around that wont require some modding, afaik.
@Rufusbduck, are you happy with the modes? (2% - 25% - 100%, off time memory and thermal stepdown controll (which is build in in driver))
Put me down for two please I will find a host but I really want to use the L2
Put me down for 4 please
Updated.
I’ll take 2
I will take two.
Regards Xandre
I will take four.
Thanks
I’ll claim 4. So this allows one cell to push XHP 35 ?
Will this work with other LEDs ??
No 2 cells
I’ll take 2 please. Will see how it does in a Courui!
If it is a boost driver, is it boosting 2 cells up to 12 V ? Is XHP 35 a 12 V led ?
If so, I will have to rethink this.
Please add more info to OP for us non-techs.
Here it is, http://www.kaidomain.com/product/details.S025108 and yes the XHP35 is 12volt. I run mine at 16.8v at 2.5amps. Going to try 16.8v at 3 amps soon!
Updated.
@KawiBoy, how do you want to use the courui? 2s3p 18350’s? Or a special configuration?
I have been thinking to use the courui too but I cant figure out the battery config.
In this thing…
Depending on modes, I’d be in for 4-5. I’d prefer 4 modes with a low-low or moon, but I’d still buy with 3 modes.
Can you verify the drive current is 1500ma? I sourced these direct from China when they were first mentioned, never purchased because I couldn’t get an answer to whether the drive current was 1000ma or 1500ma, all I got was “between” or “either” those two, which is not how a CC driver works, should be one or the other, not “between”, and I’m not committing to >10 from a vendor I haven’t dealt with before without knowing the either/or spec.
Either way, good price, put me down for at least a few regardless of specs.
Thanks for putting this together.
-Michael
ETA: That whole statement was not directed at you thijsco19, was reading back through the thread to make sure I hadn’t missed something, didn’t catch it the first time but I see now where I was unclear that sentence could have been construed wrong and could be interpreted as rude. I added the underlined/bold part to clarify. Sorry
