I am not sure eitherā¦ basically no PWM, good tint, good modes, magnet, decent clip. I am not sure why nobody is jumping in on this one. This is basically the cost of 3 emitters. Looks like the LED is easy to change, the UI looks pretty good. I think it will make a nice EDC. I wonder if it could be reamed out to take an 18350?
It could be that nobody recognizes the brand āOn The Roadā. I discovered this group buy when some asked on Reddit if this flashlight was an Olight clone, and then I did some google searching for it.
True, I did like that it is a little larger than an S1. We all like our S1ās, but a bit more size goes a long way and this one should be pretty sweet in size. Not to big, not to smallā¦
I am hoping to figure a way to put a triple in this, just for fun of course, but if not, it looks like a standard 20mm optic will fit and provide options for floodier beams if that is what you like (I do).
Brand is less of a big thing if it is made well, I picked Thorfire by comparing them to a Convoy, did not do too shabby for my first C8, but that was because I knew what to look for from reading BLF before I made an accountā¦
I would like it if there were a way to disable mode memory. I like a light to start the same each and every time I turn it on. I prefer starting on low. Iāve got buckets of lights that I never use because of the memory. It just took me a long time to figure out what I like.
I would really like this groupbuy to happen. I would also buy the light for the full price if not, but I donāt need a (probably bad) charger and battery.
Strange that thereās such low interestā¦
