If I left the moon settings as is, could I then use the moon config toggle to rather toggle the false off mode? I’m trying to think what to call a fake off mode:) have others talked about this concept for hunters or others needing an off without a click?
Bistro-tripledown is intended for attiny25, but after verifying the hardware works you’ll probably want to change some things in the code. It’s still configured more for testing at the moment, and less for actual use. You may also want to re-calculate the ramp, depending on how bright your host is.
I would like to use this driver in a dual switch light (modified Courui D01)! Control the modes with the e-switch and on off via rear switch with mode memory.
Ok, so I built a board and tested it with a working rear clicky firmware. All fine and working
Then I uploaded the new dual switch firmware and soldered a small cable to the outer ring.
I connected it to a battery and it starts in direct drive (=the highest mode).
If I touch the otc pad (=pin 2) with the small cable it should change modes right?
Anyway, nothing happens. I tried a few other pins on the attiny, but only the fet pin (=pin 3) did lower the output and as soon as I removed the small cable it was at direct drive again.
I tried both firmware versions and also tried it with and without the otc cap, because this is not needed in a dual switch light right? But no difference, I can’t get it to switch modes.
Here is a pictures of the driver, sorry it is a little bit dirty looking now.
