I’ve started work on this Ultratac K18 brass. Needs a bit more TLC and burnishing with newspaper and finger rubbing, butt I kinda like its shipwreck character.
I hung it by thread in the top of a Dasani water bottle with a few inches of cider vinegar, capped it, and swirled the vinegar a few times a day. After a day and a half it was looking kinda Statue of Liberty green in places, So I decanted and applied Palmolive for awhile.
@Chinooker Thanks for the tip. I’m trying Ajax dish liquid since the sulfates are common ingredients in dish detergents. Already seeing the color start to change after just a few minutes. Also applied to my daily use copper zippo that is very slow to develop a patina even after a few years of daily use. Both were cleaned with brake fluid, lighter fluid, and isopropyl to remove any protective coating.
Acetone I think was the consensus choice for easiest removal of the coating.
I used naval jelly, just because had it handy.
Be sure to post your results.
Gave up on the dish liquid on my copper blf a01 due to concerns about toxicity of CuSO4, cleaned it thoroughly, and switched to baking soda and water. Roughly 2 parts very hot water to 1 part baking soda. With the battery removed and head screwed down tight I tied a string through the keyring hole, set the light in the bottom of a sour cream container with about 2 inches of the baking soda/water mixture, swished it around and gently flipping it in different directions using the strong, then removed it from the mixture and stood it on a plastic lid. I repeated the process every ten minutes or so and occasionally gently rinsed the accumulated dry baking soda off by immersing the light in fresh water before starting the process again. After several hours the copper achieved a nice brownish color a bit brighter than an old penny.
@scrumpypaul I plan to post a photo of the light with a new penny and an old penny after the sun comes up to get a photo that accurately represents the results.
Did an Astrolux SC recently. First I removed the coating (and cleaned/degreased) with acetone and a soft nylon brush. Then I hit it with some vinegar (mini spray bottle) and sea salt and sealed it in a Tupperware container. I taped over the heat-sink, and later polished it up:
Since my backup new Cu A01 came in, I went ahead and went a lil wild on this one. Out-rustics my antique brass K18. Won’t say everything I stuck it in… suffice to say I won’t be holding it in my mouth for handsfree lighting! :confounded:
