KD (kaidomain): Deals and new products thread
1661 posts / 0 new
1dash1
1dash1's picture
Last seen: 9 months 2 weeks ago
Anyone know whether these C8 drop-ins work with any other brands besides Kaidomain? I’ve got a Thorfire C8, Thorfire C8s, Convoy C8 and a generic C8 (I think it’s an Ultrafire clone).
Rule 1-1 as it applies to life, take it as it comes.
mattlward
mattlward's picture
Last seen: 7 hours 51 min ago
I would think it would be most likely to work in the ultrafire. I have several of these pills, we could compare measurements. I do not have a metric pitch gauge.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
Tom E
Tom E's picture
Last seen: 1 day 11 hours ago
Possible except for the Convoy C8. Don't have a ThorFire C8 but have several generic brands, and found these pills to fit some of them. It's a lot of hit n' miss.
I used to be known as the "C8 guy" (then the "Super Shocker" guy) here a ways back wink. Had a lot of variety of them, lots of mods back before our own FET drivers.
djozz
djozz's picture
Last seen: 4 min 23 sec ago
And don’t forget that these pills fit in your UF-T20 Smile
Kaidomain, after several years, even though they seemed to have been asleep for a while, are still selling some good original own stuff, a variety of leds that are not seen anywhere else, really good drop-ins, own drivers, flashlights with a good choice of emitters, many many types and sizes lenses, reflectors and other optics. Nice!
Muto
Last seen: 24 min 21 sec ago
All I know is I have at least 15 C8’s of many makes and these pills didn’t fit any of them.
Only fit my one KD C12, but not the other one which was only 8 months older than the new one and was also a KD model.
I used the driver on another light and pulled the XPL HI for another light.
Still a good deal, just wish the brass pill could be put to use in other lights.
Just my experience.
Later,
Keith
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
Big Sky Country
No matter where you go, there you are.
1dash1
1dash1's picture
For the $10 risk, I think I’ll pass.
If I’m going to throw away money, I’d rather pick up another Ganzo knife that-I-don’t-need rather than a pill that might-not-work-and-I-don’t-need.
Or send it to my favorite Presidential candidate, again that-I-don’t-need. 8-)
BanL
Last seen: 2 days 3 hours ago
Hi guys
Thanks for your interesting with KD C8.
There are many different C8 products in the market. As you know, C8 has a very long history. It has many different variation, generation. For the KD C8, it is a standard C8 version.
I will list the measurement for this pill. You can know more that it is supporting to your own C8 or not.
Overall Pill Dimension: 26mm(Dia.) x 13.5mm(Height)
Upper Part:
Outer Part: 26mm(Dia.)
Inner Part: 21mm(Dia.)
Bottom Part:
Outer Part: 19.5mm(Dia.)
Inner Part: 17mm(Dia.)
Thread Spacing: 22mm x 1mm
This pill is better used with the Lens with 2mm thickness.
If you have any question, please feel free to contact me.
Best Regards
Ban
kaidomain.com KD - LED Flashlights, DIY Parts and Accessories
Inquiry for KD, please feel free to contact me.
Muto
djozz,
Thanks for the heads up on fitting the UF-T20.
Just got done doing the swap, retaining ring on the lens was a bear to get loose but after that it was easy.
I left the shorter spring on the KD drop in intact, now the light will accept longer batteries without a fuss and still runs shorter unprotected cells as well.
Now it is bright, great tint and no rings, Got me a new Pocket Rocket:)
What do estimate the throw/lux to be after this swap?
Big Sky Country
djozz
djozz's picture
My UF-T20 with dedomed XP-G2 R4 (yes, that was a long time ago), did 108kcd (at 2.95A). The newest bin is S4, which is 26% brighter, so that would throw 136 kcd. The XP-L Hi has a die size 2.2 times bigger, with the same current and output the throw could be 62kcd. But bigger dies project relatively well in aspherics (the poor lens quality is more forgiving towards them), and the bigger die XP-L has a bit better output at 3amps and thermal management, so a rough guess could be 80kcd.
But reality could be very different…
BanL
Hi Guys
Cree XP-E2 Red / Green / Blue P60 Drop-in available in KD.
For input voltage 3V – 4.5V
Cree XP-E2 R2 Red 620nm 3V – 4.5V 3-Mode OP LED P60 Drop-in (Dia. 26.5mm)
http://www.kaidomain.com/product/details.S025006
Cree XP-E2 R2 Green 530nm 3V – 4.5V 3-Mode OP LED P60 Drop-in (Dia. 26.5mm)
http://www.kaidomain.com/product/details.S025005
Cree XP-E2 M2 Blue 470nm 3V – 4.5V 3-Mode OP LED P60 Drop-in (Dia. 26.5mm)
http://www.kaidomain.com/product/details.S025004
For input voltage 3V – 12V
Cree XP-E2 R2 Red 620nm 3V – 12V 1-Mode OP LED P60 Drop-in (Dia. 26.5mm)
http://www.kaidomain.com/product/details.S025009
Cree XP-E2 R2 Green 530nm 3V – 12V 1-Mode OP LED P60 Drop-in (Dia. 26.5mm)
http://www.kaidomain.com/product/details.S025008
Cree XP-E2 M2 Blue 470nm 3V – 12V 1-Mode OP LED P60 Drop-in (Dia. 26.5mm)
http://www.kaidomain.com/product/details.S025007
Thanks
djozz
djozz's picture
Found 14mm x8mm boot caps in refreshing different colours, ordered some Smile
http://www.kaidomain.com/product/details.S024982
BanL
New Big reflector is arrival
86.2mm(D) x 84.7mm(H) OP Aluminum Reflector
US$18.65
FmC
FmC's picture
Last seen: 5 days 15 hours ago
US$18.65
Nice, an OP version.
I may have to pick one up to drop into my modded L3, & change over to XHP + FET
BanL
Another Cree XHP35 HI is arrived to KD
Cree XHP35 HI D4 1A White 6500K LED Emitter
Cree XHP35 HI E2 3C Neutral White 5000K LED Emitter
And there is some solder on base plate. You can take a look on these.
Thanks
Rolz
Last seen: 2 weeks 1 day ago
Thanks
Looks interesting. Will be great to see some flashlights based on these LEDs. A 3 x LED model with Multiple batteries may be the answer here as the forward voltage is high.
BanL
Dear ALL friends
We are now released a new version of KDLIGHT 7135 Driver board.
New Updated:
1. Added Battery Reversed Protection
2. Add the short 4.2mm (H) / long spring 12mm (H) version
3. S1, S2, S3 and S4 solder pad and ground jumper will be closer to let you solder easier
4. 16 totals programmed output modes can meet your needs
5. Low voltage warning and LED auto shut down to protect your battery
KDLIGHT 7135 Driver Board
Also, we had introduced a new brand KDLIGHT. We would continue to offer the product with good quality and high Price–performance ratio.
If you have any comment on our product, please don’t hesitate to contact us.
Thanks
Ban
brted
brted's picture
Last seen: 1 week 2 days ago
Looks like a great driver with lots of options. Thanks!
mattlward
mattlward's picture
Looks like a nice regulated driver! But a steel spring… really?
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
keltex78
keltex78's picture
Last seen: 1 month 1 week ago
Nice! Interesting selection of modes here, and the longer spring is a nice addition:
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
BanL
Hi Mattlward,
This is not Steel Spring. This spring is brass material with silver coated.
The spring wire size is 0.7mm.
Thanks
Ban
djozz
djozz's picture
Last night I ordered one of the KDlight V3 8×7135 drivers. I like the added reverse polarity protection and how it deals with low voltage. The mode spacing is good and unlike the Qlite you can choose for no memory, which is essential for me.
BanL, do you happen to know what the PWM frequency is (too high to notice I understand but how high?)
If it works as it sounds, it is going to serve in a mellow XP-G3 high CRI triple build. Smile
mattlward
mattlward's picture
Hey BanL, thanks for the reply… Guess I will need to order a couple! The specs look great, I like regulated drivers in many of my EDC lights.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
giorgoskok
giorgoskok's picture
Which is the new KDlight?
Also will you get more cheap C8 hosts ? (like the old with red leds , they were great hosts).
mattlward
mattlward's picture
I really like the KD C8’s as well, good selection of parts for them as well.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
brted
brted's picture
They have a 5-mode XM-L T6 C8 for $10 on clearance (bottom of the home page)
BanL
Hi Djozz
Thanks for your interesting with the new driver board.
The PWM frequency is 15000hz.
Thanks
Ban
BanL
Hi Giorgoskok
We will update the new product desc asap.
We have re-designed the new reflector for the XP-L HI LED .
Thanks
Ban
giorgoskok
Hi Giorgoskok
Thanks
Ban
Thanks Ban !
Some beamshots would be superb!
mattlward
mattlward's picture
Well heck, I am going to have to order another reflector and pill and try the XP-L HI now that it is optimized! I have several of their C8’s, not as clean as Convoy but very functional!
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
djozz
djozz's picture
Hi Djozz
Thanks
Ban
I got the driver in and without having tried it I’m impressed by the number of settings (my favorite low-med-high-without-memory can be chosen, unlike intl-outdoor’s qlite) and by the good connection between batt+ and led+ . The 7135 chips are branded and look the same as Mtn El. uses. Good to hear that the PWM is unvisibly high.
One more question: the manual speaks about thermal protection (output step-down) which is a great feature, but I know that the Attiny13 MCU does not support temperature sensing. This MCU has its branding sanded off, but is it the Attiny25 or the like that does have temperature sensing?
