Great I will try changing to some of my fet+1 drivers to attiny85 and e-switch with narsil !
Do you have a EU source for the attiny85 ?
Dutchee, fantastic write up for this phase of the mod. Really appreciate the pics, and happy it is all working for you…
You can buy them at mouser. But due to the shipping cost, I bought a few from ebay.
These are the ones I used:
Ebay 5pcs Atmel Attiny85
Nice driver mod. I admire you guys modding and building these items.
Sorry, I think I missed this post…
Yes, with a tiny solder tip it should be doable.
I had to resolder the black wire to the switch while it was glued in the head. It came loose when I removed the driver to add the kapton tape. So I think desoldering should be relatively easy.
When heating the whole head as you mentioned, you might melt the rubber boot over the e-switch. Also the original glue might burn. I think its safer to remove the driver before the LED reflow.
Excellent job on this mod! Wish I had one of these lights, because this mod looks great for it.
Let me know f you have any flaky problems with the light - mode changes, going in/out of strobe or hi, etc. Most Tiny85 builds I had to tweak things to get it working reliably - add another 10 uF cap stacked on C1, or air wire a 0.1 uF cap from pin #4 to pin #8. Now could be more of a problem with the SIR800DP FET's I use, but probably still happens with regular FET's. Richard's new MTN-17DDm driver that supports a Tiny25 has several changes to properly support 25/45/85's.
Thanks for the nice replies, guys!
On the pannie cell it doesn’t overheat. When allmost burning my hand, it steps down at 30sec’s. On 35% it slowly loses the excessive heat. I don’t plan on testing this in a pocket though… I still have to do a tailcap reading on the pannie…
It does heat up real nicely all the way to the tailcap. But the cell stays quite cool, unlike in the stock DQG where it serves as a heatsink…
On a 30Q cell the strobe is so bright, it actually gives the same effect as a stroboscope in a discotheque!
@Tom E: Besides the somewhat high temperatures, I didn’t notice anything flaky, not even once. All modes work flawless so far. Really the nicest U.I. in a light I own. I usually EDC small twisty 10440 lights, so the lack of unexpected mode changes is something I’ll gladly get used to. Really nice with the e-switch.
But if I’ll notice something strange, I’ll give you a head’s up :+1:
Edit: Tom E just made clear there is not thermal stepdown in Narsil, so the heat has nothing to do with any flaw in the driver or Narsil. It actually performs 100% in a super hot light :+1:
That's all good then. I've had the same luck with a few drivers converted to 85's, but more recently, I just do the cap mods, not wanting to take a chance. The FET tused is a big factor in this.
Absolutely outrageous! I have two Tiny 18650’s, have wanted to mod one forever. This is a little beyond my present skill, but I enjoyed your post immensely.
Awesome job Dutchee!
Question: How do you reflow an MCU from a driver board? I tried it once on a Nanjg 105c and ended up destroying the pins. Do you just apply the iron to the plastic package and hope it melts the solder? What kind of iron do you use?
@ rmkline: Thanks for your enthusiasm!
Just order all parts x2 and see how far you can get. You already have 2 hosts :laughing:
Firelight2 is part that got me into this mess :person_facepalming:
Just like his nice build review on #3, I hope this opens doors for more mods on the DQG 18650. I haven’t found a better host so far… It actually drives the heat out better than I expected. I usually EDC titanium lights, but these suck at thermal conductivity.
@Firelight2: Thanks!
I place the driver on the two wooden blocks, like in the pic’s.
MCU side up, solder tip between the blocks under the driver pushed against the + battery pad, just slightly lifting up the driver. I had some solder on the + pad, guess that helped in the heating process. Not needed though I think.
After about a minute or two you can pick off any component with a tweezer. You can see it’s ready when the solder turns shiny. Don’t drop the driver at this point
I cleaned off the excess solder with copper unsolder wick, working from the top.
I bought my iron at a local hobby shop at around €20, will let you know wich type. I’m not home at the moment. It’s got an analog temp. selector wich I use on high most of the times.
Edit: I used this solder tin paste for the reflow of the AT85:
Ebay solder paste
Wow thanks for the tip! So all I need to do is apply my soldering iron to the + pad on the underside of the driver :sunglasses:
I figure my 40w cheapie soldering iron should be hot enough. But if not I suppose I could swap to my 60w iron.
Hm… wonder if I should learn how to flash driver firmware.
Haha, that’s not a question, is it?
I wish someone would come out with an e-switch driver with temp sensor. Something like the H17F, but for e-switches would be perfect. Hint, hint …. if you’re reading this thread DrJones :money_mouth_face: :money_mouth_face: :money_mouth_face:
I wonder if I should mod my DQGIV into a triple.
I like the stock DQG IV much better than the DQG III, but I still find the UI annoying. The light would probably be better as a small triple!
Alternatively, I could mod my BTU mini titanium into a triple. It looks like a slightly longer DQG mini, but made of out of titanium. It would actually be possible to make this one into a non-triple with a different driver and emitter since unlike the DQG this one has an actual separate star for the emitter. Downside is the titanium. The head gets too hot to touch even with just the stock 2.8 amp driver.
That would be very nice indeed!
Maybe someday we wake up, and Tom E, DrJones, TK or some other code magician saw the light to get BLF the holy grail of e-swith with thermal regulation FW :innocent:
Really, with this output and firmware, it’s a completely different light than the stock DQG.
It’s no longer a dumb light, it’s programmable. Tint is way better, superlow moon, MAX…
My uv-s5(SRK) ceilingbounce is 156lux compared to 233! on the DQG :disguised_face:
I really like the looks of that BTU mini titanium, but the material is not suited for a FET DD triple IMHO. Single emitter might be oke for short use I think.
Don’t you use your DQG 3 triple anymore? That looked nice!
Did you go back to a lower output EDC light, while you’ve spoiled yourself with such a small powerhouse? :question:
Maybe I’ll throw my DQG into a sodium hydroxide solution one day and give it a polish… I think the knurling is a bit too agressive and love bare lights… Maybe…
These days I’ve mostly been grabbing my 18500 powered Sunwayman C10R when I want a superbright triple. On an Efest 18500, the Sunwayman is as bright as the DQG Tiny III triple on a Samsung 30Q (both lights use the same FET driver). It’s actually even a tiny bit throwier due to the lack of extra lens in front of the optic.
Unlike the DQG, with the Sunwayman there is no heatsink slug under the star, but on the other hand, with the Sunwayman my hand does not sit directly on the hottest part of the head and the head has heatsink fins. I can’t run it at full power as long as I can my heatsink modded DQG, but the light makes up for this with its much smaller size.
Of my two DQG Tiny III triples:
- FET Driver version. The one with a FET driver and external heatsink works very well and feels very good in the hand. But I put some Sugru around the button and as a collar around the base of the heatsink. This fixed a couple of my problems including making it so I can hold the light substantially longer at max power before it gets too hot to hold. And unlike the metal switch I was using this one is waterproof. Downside is the Sugru looks pretty ugly. I’m thinking of replacing the Sugru with green stuff epoxy and then painting the entire light with Duracoat for a much more uniform appearance.
- 3.8 amp Mokkadrv driver version and no external heatsink. The exterior of the light looks absolutely beautiful. But since output is capped at 3.8 amps it’s not a pocket rocket (Mokkadrv has no turbo timer and always comes on in max). Also, the metal switch isn’t waterproof. I suppose I could replace the driver on this one with something better.
Nice job on the sunwayman! I can see why you like it. You modded a nice couple of small lights.
Today I removed the anodisation of the DQG using sodium hydroxide (declogger)
I don’t really like the ano on the DQG. It looks a bit cracked and had some scratches. The light had some sharp edges and the knurling is too agressive.
Dissolving the anodisation in a lukewarm solution:
I polished the knurling and some surface parts. The knurling now feels very nice. And all edges are more “refined” now.
The weight was reduced with 1gram to 45.1gr.
This light couldn’t be better…
Nice work for one more time
That bare polished DQG looks great! Awesome job!!! :sunglasses:
Great looking mod.
I like it that much I’ve got a dqg tiny 4 host on the way to copy it.
Couple of questions.
What size is the driver and how is it held in place?
The switch, is it sitting on top of the copper heatsink you put in?
Thanks for your help.
