I think what @tarver asking is why his 2 batteries take on different amount of charge after being used in his EC4S.
Running a discharge test will shows the capacities of both his batteries, which is another issue whatsoever.
But if he has not done so, it is best for him to do it first so that he can concludes that both batteried that gone into his EC4S has roughly the same capacity.
To me, if @tarver try 2 more new batteries in his EC4S and still get different amount of charge to refill, it’s more likely due to his light.
Thank you for your quick answer !
As I am always testing capacity of my rechargeable batteries, I was not really sure if my measurements were really accurate using my, in comparison to yours, budget equipment.
I have got 12pcs of 30Q and I am quite happy to see that my measurements pretty much match with yours (I´m just doing simple capacity testing up to 3A).
I need a help about INR18650-30Q battery manifacturing date code.
For the other Samsung elements refers written below:
■ Cell package : The bare cell is packed by which packaging material, PET tube.
■ Model and tube marking : there are three lines on the cell tube as follows.
Line 1 : INR18650-25R —- cell model name
Line 2 : SAMSUNG SDI —- cell manufacturer
Line 3 : 2D51 —- date code (Capacity ; “2” is over 2.0Ah, Year, Month, Week)
But 18650-30Q element have different Line 3 code. Only three letters. The principle of the code is different. I don’t know whether the item is new or 1-2 years old.
Since the Samsung 30Q is a relatively new offering, it simply cannot be 2 years old.
(I do have an atrocious time line memory, so 2 years could be “new” to me, sorry if that is the case. Bottom line is, it really can’t be an old enough cell to really matter. Authenticity would be far more important and there are other identifiers for that.)
There are three lines on the cell metal can as follows.
Line 1 : J5D5 —-
1st digit: Line number ( “1” for cylindrical line No.1, “J” for cylindrical line No. 8)
2nd digit: Final number of Model Name (“5” is INR18650-25x)
3rd digit: Year ( “D” is 2013)
4th digit: Month ( “5” is May ; A is Oct., B is Nov., C is Dec)
Line 2 : 45221 —-
1st digit: Negative coater number ( “7” is No. 7 coater)
2nd ~ 4th digit: Batch number
5th digit: Serial No. of assembling
Line 3 : 62F1 —-
1st digit: Date (“6” is 6th day ; 10 is A, 11 is B…)
2nd digit: Serial No. of winding in a batch
3rd digit: Reel No ( “F” is F reel ; A is A reel, B is B reel, … F is F reel)
4th digit: Winding Machine No. ( “1” is No.1 winder)
Button top 30Q are available from Gearbest if you need to use these batteries. I used this code last time (not sure where it came from) and may still be valid. a59300.
This definitely is a very good battery. I studied HKJ comparator for awhile. Only the relatively new VTC6 beats it in all of the voltages. Not by much.
The 30Q is ~$4 cheaper,in that sense it would probably be the best choice. From a visual perspective and a performance perspective, I doubt if there would be any noticeable difference.
I have One of these for the last 1.5 years and it is still working well. i have a pair of VTC6,so far they are working well!
Thanks for that update VW, I was just about to pull the trigger on some at BangBang… with a code and points. :person_facepalming:
Not even gonna waste my time now,
I’ll just get em here in the USA & pay a bit more & have them in a couple of days.
I have no problem using any of my 30q in series. I have 4 put up I use in l6 and s70 to save weight of 26650s if imma be holding it for awhile. Got two from imr batteries and the other married pair from GB
Mine are flat tops, pretty much all I buy now. Only have one light now that requires a button top. The nitenumen
If I’m scanning for critters and/or need long turbo time I’ll use the 26650. But I’m walking with my daughter at night up to the park and just using high setting I’ll use the 18650 and bring the spare set. And spare light of course.
The 30q is one of my favorite batteries. I use it in my vape unit as well its a single 18650 unit. So I don’t have to worry about married pairs besides the 2 sets for my heavy hitting lights. I don’t hit more then 9 amps at most. Lots of 30q and mj1/ga. The mj1 I like a lot to because at 10 amps still has roughly 95% of its original capacity. Compared to 30q @10 goes down to 2700. But still my favorite battery nonetheless. For $6 a piece and can power my x6 triple, my vape and all my other lights and be 3000mah works for me. I dont like running batteries at their amp limits. As the cell ages and resistance increases id rather have some cushion room. But I’m not happy with just one battery. I have to purchase some of all of them just to have them in rotation. Some reason I’m addicted to batteries as much as flashlights.
I just cleared out my night light batteries to recycling. So picked up a couple new laptop batteries off eBay (Samsung 26h). To use for nightlights and waste my good batteries cycle life on lamp use
I see that VTC5A and INR18650-30Q have exactly the same IR in HKJ’s tests. They are extremely similar in akkudb too (similar to each other, not similar to HKJ’s result). Nevertheless, when looking at discharge curves, VTC5A sags much less. Why is it so?
