Freeme Review: JETBeam JET-1 MK 480lm XP-G2 14500/ AA - incomplete, pic only
Overview:
Brand: JetBeam
Model: JET-1
Price: $21.99 (for discount)
Emitter: CREE XP-G2 Cool White
Brightness: 480LM (manufacturer rated)
Mode: 3 Modes
Peak beam intensity: 4,200cd
Lens: Toughened Ultra-clear mineral glass with Anti-reflective Coating
Material: Aircraft grade aluminum alloy, military type III hard anodising
Mode Arrangement: Low, Mid, High
Mode Memory: Yes
Battery: 1*14500/ 1*AA
Net Weight: 16.7g (w/o battery)
Size: 19.5mm (head), 19mm (tail), 83mm (length)
Waterproof Standard: IPX-8 Standard Waterproof up to 2m
First Impression:
Close up look:
Weight:
User Interface:
Interesting Features:
Performance: Tailcap Amperage Readings
1) Tailcap measurement:
Low: mA
Mid: mA
High: A
Parasitic drain: --- μmA
Performance: Runtime
Beam Profile: Tint
Flashlights are projected to a sheet of white acrylic at a distance of 15cm.
PWM (Pulse Wave Modulation):
PWM is pretty obivous in Low and Medium mode when you are using 14500 rechargeable battery.
Size Comparison:
JET-1 MK's color and finishing matched my favorite Niteye flashlights.
What I Like About JETBeam JET-1 MK:
  • Very attractive design. Typical JETBeam/ Niteye standard
  • Excellent machining and finishing.
  • Perfect EDC size.
  • Support both 14500 and AA batteries.
  • Good placement for logo, model, and serial number.
  • Threads are smooth to operate and well lube.
What Needs to Be Improved:
  • Lens fog up when light is turned on. Output level will be affected.
  • Slight tint shift to cool temperature when head turns warm on High.
  • JET-1 MK does not have a circular beam profile.
  • Although the threads are smooth, I suspect the threads are a bit loose.
  • Sample unit is slightly slanted when standing upright on tail.
  • Tapped screw hole has very limited usage. Most likely it is going to attract dust from your pocket.
Conclusion:
Coming soon
Our Rating
Power: ★★★✩✩
Easy of Mod: ★★★✩✩
Price: ★★★★✩
Overall value: ★★✩✩✩
Reserved for updates.
Ough! Not easy to mod? I was already imagining a 4000K light :frowning:
Thanks for the quick review
I could see that there a little gap in here. I tried to open with my bare hands but it seem to be sealed.
Haha, nothing is un-modifiable for the experts. LED swap is still possible at this stage.
Nice review and pictures! I hope the bezel opens with a bit of heat and brute force, planning to swap for a XP-G3.
Is that fogging in your light because of moisture?
Thank you. You will definitely need some help with the tools. Almost none of my lights exhibit such issue. I just left the light in my dry cabinet, will verify if it is due to moisture later.
Images are superb. You understand how to correctly light a scene. :+1: Disappointed about the flashlight’s very cool tint. Looking forward to the rest of the review.
I like dark-gray and smooth anodising typical of Jetbeam, nice that this little lights also show it; very good pictures freeme; I am again hopeful about a 4000K nice Jetbeams.
Lens still turns foggy after leaving it in my dry cabinet over night. Doubt there is much I could do, unless I open up to find out the problem.
Nice pictures!
I also have the light on order and after seeing the tint in your pictures I definitly want to change the led and if possible the mcpcb to a copper one (just to have it in there :wink: )
Can you do a runtime graph? Someting like that would be great http://i1024.photobucket.com/albums/y309/Budda_CPF/Manker%20E11/E11%20XX_zpsutk7ytpn.png
Glad you like it. I will get the runtime chart up soon!
Great!
Nice review!
I like its overall design, but IMO the head’s design is quite plain.
really great pictures!
thanks for the review
I wonder if that tapped screw hole that you mentioned can attach a jetbeam defense/window breaking cone. Thanks for the pics!
Update:
That is bad, how is pwm with a nimh?
No visible PWM with AA.
Thanks a lot for all the effort! I think that I´ll skip this one. Also it is a twisty… I don´t like AA twisties. :wink:
Still trying to unscrew the bezel …
