Thanks Don!.
Seems to be a good light, at least if you see the desing and light output... but I dont beleive that this light is fully regulated (I mean, current increases as battery voltage decreases)
Thanks Don!.
I also vote BLF edition of this light ;) with special BLF price hehehe.
See New beam shots.
Thanks for the beamshots. That beamshots are with 14500 or nimh?
14500
Got my xp-e in Sweden the 25:th, shipped from CQG the 21:th, thats crazy fast!
Ordered it as a gift for my dad and liked the design much better than my Xeno 03 T6 NW so I ordered a T6 CW for myself yesterday! :-)
If I had known that there would be an XM-L NW version, I would have waited for that.
I probably would have, too, but now I'm kind of glad I can compare the two. My problem was buying the XM-L from Tactical HID instead of CNQG because that was the only vendor carrying it at the time. He took the order but the drop shipment wasn't nearly ready and it took two weeks just to process. I had no idea Ric would be carrying it so fast, since it was ME who informed him it was actually available just a few days earlier. haha
I actually discharged one till i believe 2.1V open circuit and another time 1.7V open circuit.....so that's VERY low. But i recharged them immediately when i saw that the light was so dim. Still able to dump nearly 2.3A into the Xeno E03 when fresh, and nearly slightly over 3A in the Ultrafire XM-L drop-in so there's no damage i guess. These cells are good.
I have this torch. It's a winner. Mine draws 2 amps from a 4.1V 14500 trustfire. Pure flood power on a extremely nice built flashlight.
To all you talking about the IMR: Be advised this flashlight has a "reverse polarity protection", a nylon ring protecting the positive contact on the driver. That means flat top cells (such those BIO IMR's) won't make contact with the driver. It also has gived me some trouble with some of my trustfire flame 14500, but It can be solved using a magnet spacer. Anyway there's enough room for the protected 14500 + the 1mm spacer. ( I didn't have this small size magnets so I broke one and used the pieces)
I still don't know how to dissasembly the pill for removing this annoying "protection".
EDIT: you can check my wn review for forolinternas.com here: http://www.forolinternas.com/viewtopic.php?f=5&t=2756
Its a nice torch, but I would like a more even design better. The head and tail "fatter" than the middle. Hopefully Balder makes one soon! they are really good priced!
More Tail cap readings
Orignal
Tail Cap readings
Ni-MH Trustfire Flame 14500(4.14v)
High 2.23Amps 2.45Amps
Medium 0.78Amps 0.74Amps
Low 0.06Amps 0.02Amps
New readings using 8 batteries
4.02v 2.06Amps 0.61Amps
4.05v 2.22Amps 0.68Amps
4.06v 2.18Amps 0.63Amps
4.08v 2.20Apms 0.67Amps
4.13v 2.40Amps 0.73Amps
4.14v 2.54Amps 0.75Amps
4.16v 2.53Amps 0.73Amps
4.18v 2.56Amps 0.77Amps
UPz, i always DIY a nipple with solder for my flat top IMRs, Panasonic, Sanyos.
My flat-top IMRs work(ed) just fine. Picked my one up from the PO this morning. I really am not fond of forward clickies in multimode lights.
Time to do some playing testing
Nice finish. Could do with some more threads at the head end.
Worked in the office - now at home refuses to emit light. Ah well, it isn't going to get used for dog spotting in the park tonight.
Don see if your readings are high as mine
Would if I could get it to emit light. Will need to have a look inside to see if it is something easily fixable or if I need another one.
Don: Check the battery positive contact. I had trouble with some 14500 on this flashlight due the "reverse polarity protection"
Wish it were. I've tried it with assorted NiMH, NiZn, alkalines, 14500, IMR 14500 and magnets where I thought it'd help.
It isn't the switch - it tests OK and jumpering with a wire still produces no light. Will need to see if the pill can be persuaded to come out and whip the insulator off the LED.
But first will take the assistant out to let her carry out her wide range of eliminatory functions. Then I'll get to do stuff without her "helping".
Some of my Trustfire 14500 had problems lighting the light it's the white ring - reverse polarity protection that effects this.
Just emailed them to see what their response will be - the problem is clearly in the pill and is therefore probably not user-serviceable.
