Rofis JR10 triple XP-G2 to 18500 cell and MTN FET moppydrv electronic switch firmware
I think that Rofis mod is the first time I’ve seen a triple in a “periscope” light. Pretty cool. How is it for heat sinking?
Being honest, due to the swivelling design heatsinking is not the best but the heat does transfer down the body too.
There is a chunk of aluminium spacer behind the triple noctigon so that helps some but 100% mode is for brief use on this.
The original driver was really good but i had an accident with that …
I really like this light as it is so comfortable to use in “periscope” mode (never heard that one before) and now with the tail switch gone it is even easier to operate.
Nice job on the Rofis!
How is the electrical connection handled between the body and head? Are there wires which bend each time the head is swiveled?
Thanks, yeah there’s two wires going from the body to the head through a hole in the centre of the mechanism, i replaced these with thicker silicone wires.
I did try to open it up once to see how it was made but i couldn’t figure it out without damaging it.
I just started out so nothing spectacular. I modded my old 2D Maglite to fit 18650’s and the 225 lumen led drop in. It’s nice not to have to junk it but obviously it uses are limited compared to other lights. I think this is my “gateway” light, I’ve been watching a lot of videos by Old Lumens and others so this is just the beginning.
Nice place to start and you picked a good member to emulate.
You cant go wrong watching OL videos. They are very inspirational.
I didn’t mod anything today but….received my first order from Russia from Kiribi-ru. S2+,S2series, x6, x5, spacers, triples, quads, optics on and on. Very well packaged in a case all separated. Looking forward to this! Hey…retired guys can have fun too.
Emitter swapped the emitter in my Sunwayman V11R mirage.
Finally figured out how to use strap wrenches properly so there was no damage to the anodizing. Replaced the cool white XML U3 with a 5000K XPL HI of unknown bin. Didn’t bother filing a Noctigon down to size. Just grabbed the nearest approprriate sized aluminum star. Tint, output and throw are much improved.
I give the body of my v10r ti some work. Ideally I wanted to knurl the body but a couple of things prevented me from doing so. 1. I haven’t worked with Ti before and 2. I would need to cut the body right back to get it cylindrical again, I don’t know if the walls would stand up to the knurling tool after that.
Unfortunately I cracked 2 of the 4 trits in the tail. I have no idea how I did that on a 3 jaw chuck???
Bugger. How far into the machining did you get?
Wasn’t sure I understood your question but then I noticed pics weren’t showing again :weary: I don’t know what up with that, they’re all coming from the same file???
the Lii-100 is a USB-powered multi-chem-Charger with Powerbank feature
on google i stumbled once over an mod by hypertonie from a german forum - he upgraded the charger with an small voltmeter
and so did i... - now its also a LiIon-cell-tester!
i bought the Voltmeterhere: http://www.banggood.com/0_28-Inch-2_5V-30V-Mini-Digital-Voltmeter-p-9742...(link is external)
do not forget to adjust the potentiometer for accurate reading!!!
open the Lii-100, cut a rectangular hole and fit the voltmeter (2 drops of glue)
done!
Another fun build finished.
Installed a 15mm FET driver in my Thrunite T10T triple XPL- HI.
Modified forward clicky.
Aluminium heatsink.
Some decorative lines on the tube.
Around 9Amps startup on turbo mode :sunglasses:
And yesterday Vollsion SP-11 s with driver mod, XP-L HD 2C and magnetic tail.
Wow, I really like that volt meter mod! I think I will mod a few of my Lii-100s!
I did a shorty S2+ triple with red Nichia 219B's today.
I did a test on these leds the other day that I still need to publish, it performs well but not as good as the red Cree XP-E2.
For the mod I sawed the pill in the middle so only 6mm of the driver side of the pill is used, and the triple Noctigon was soldered on top of the now hollow pill. Together with the short Carclo 15070 optic (the stock glass lens was kept in place), and a smaller spring in the tail, this made the battery compartment 18500 size. I tested the output with a Sanyo 1700mAh 18500 battery.
For a driver I used the new KD-light 3A lineair driver. At least in this application this driver is not ideal: by soldering the S4 bridge I have set it to a simple low-med-high no memory, and low appears to be 4.5mA / 0.14lumen, med 140lumen, high 3.05A / 340lumen. On top of this very bad mode spacing, changing modes goes pretty awkward, every time you click to change mode it first goes to low. So if you want to go from low to med you have to click low-med so two times, if you want to go from med to high you have to click low-med-high so three times. Even though I quite like the red moonlight mode, I may change the driver sometime.
The 7135 chips have to burn off a lot of overvoltage when using red leds so they have to be heatsinked well. But in the S2+ the screw-in driver retaining ring can not be used when there are 7135 chips on the battery side of the driver, so the driver has to be soldered to the pill, and while I was at it I made it big blobs where the 7135 chips were. For this type of soldering my 80W Antex soldering beast is ideal, it is a breeze to solder stuff to brass pills with it.
The beam is nice, a distinct very red hotspot with a not too obvious 'starry' edge caused by the three rotated square projections of the led dies (so a 12 pointed star), see short video of the white wall beam while rotating the flashlight. (mind that red leds do funny things with camera's; in reality there's no sharp edge around the hotspot but it is all smooth and one single colour)
This light will get a (red of course) lighted tail, to be done later.
Nice. I hadn’t even considered coloured nichias. From the video it looks slightly more cherry red than the XPE2. How is the heat handling with the sawed off pill?
Do nichia make any weird colours I don’t know about? Im looking for something different to try.
