limited stock! - coderequests via mail to: m4dm4x [at] aon.at
KLARUS XTQ1
CREE XM-L2 U2 800LM 18650 Waterproof LED Flashlight
https://m4dm4x.com/2016/05/31/6-99-usd-blitzwolf-4-8a-24w-dual-usb-travel-wall-charger-2/
EU code:54d131
This coupon has expired
Can you send me another one?
Hi Martin, just got the Niwalker MM18 from hkequipement, very good deal, thanks again for the coupon.
if you are interested in the Klarus Mi7 - send ma a PM ;)
M4X, do you ever get good deals on low self discharge NiMH cells?
banggood had eneloops - but "only good" prices
and i do not know how good these are:
Xiaomi | 4PCS Original Xiaomi ZI5 AA 1.2V 1800mAh | 328d9f | $10.46 |
Yeah, I see Eneloops and Fujitsu for not much over $2 per cell for a dozen or more quantity, but not often or predictably.
hank, check Ikea Ladda cells, the white ones:
They are produced in Japan, most probably in FDK Twicell factory, performance is on par with ‘original’ Sanyo Eneloops i.e. better than newest Panasonic Eneloops made in China.
Hey there M4DM4X, not sure if you had te opportunity to send PMs yet. I’m keen on the Klarus
did you request the info via Pm ;) ?
i answered a lot...
Hey Martin,
would you please send me a message too bout the Klarus
Thanks, Martin, for all you do here on BLF.
Code, please, for Nitecore EC4SW.
PM sent regarding the you know what.
Astrolux SC code worked for me today. Thanks!
thank you all!
that GB is alive atm - but please do not public post infos - stay private if you communicate ;)
which GB?
Also interested, I do likey GB’s
Hi!
the great little
is available for only US$ 3.90 at banggood atm
it is a USB-powered multi-chem-Charger with Powerbank feature
on google i stumbled once over an mod by hypertonie from a german forum.
he upgraded the charger with an small voltmeter
and so did i... - now its also a cell-tester!
i bought the Voltmeterhere: http://www.banggood.com/0_28-Inch-2_5V-30V-Mini-Digital-Voltmeter-p-974258.html?p=IO0117468906201403!A
do not forget to adjust the potentiometer for accurate reading!!!
open the Lii-100, cut a rectangular hole and fit the voltmeter (2 drops of glue)
done!
Nice little mod MM.
