The model I have to review has a smooth reflector which helps with throw. If I get an opportunity to gram an OP version to test out I’ll pass on the beam shots and results.
Still looking for your C8? lol the OP will make the beam less of a thrower and it will also give it a warmer appearance I build a C8 with a OP textured reflector like these ones its nice it still throws far but no where near as much as a standard C8 as for power @ 3 amps these will maybe just 1000 lumen nothing spectacular same package as what convoy is offering but it appears that these lights have no centering ring the reflector is custom made to sit on the MCPB i cant tell for sure because no one has to taken pics. Other thing is the driver looks like it is soldered in and doesn’t use a retaining ring…
@Every
Yes still looking for a thrower C8 for the boys (’I’ve got a stock SMO Thorfire C8S)
Just considering my options mate
@Rolz
A review of the OP C8 would be great especially for someone new like me
I’ve started collecting data for the new C8 from KD and the results are great so far. About 70k on the lightmeter at a spacing of 1m. It’s an excellent thrower for it’s size. Best SMO C8 I’ve seen to date. At this time I may not be able to test it with an OP reflector. Once the review is over I may try, but it’s not a simple swapover. I may need an LED gasket. Anyway I’ll explore.
The KD C8 is not a well-optimized use of the XP-L HI. The same ugly yellow center can be seen, and while the throw is great, the beam looks messy to me. Looks like a poorly de-domed XM-L T6.
The only good use of XP-L HI is in the KD P60 drop-ins. No ugly yellow center and great throw.
Rusty are you referring to the newly released KDLIGHT C8 or the earlier versions? The Cool White version I have of the new model has a nice clean beam pattern.
I am referring to the newly released lights. I gave them away to friends. They are functional and bright, but they suck. I now hate XP-L HIs because of the coloration issues. They are really ugly.
Joe, were the ones you had Neutral or CW? Also how long ago did you order them?
I thought the newly release versions were just put on only about 1 week ago?
Good to hear this, thanks! I’m planning on getting some of these.
Anybody know if there is a way to change mode group on KDlight V3 driver without resoldering ie. with button clicks when the driver is inside the flashlight?
Or is it solder-and-forget and no way to change without jumper resoldering? I don’t suppose there’s dip switch out there small enough to fit?
Hi friends,
Nichia NVSW219BT-V1 R9050 D220 SW57 5700K CRI92 LED Emitter is in stock now
http://www.kaidomain.com/p/S025678.Nichia-NVSW219BT-V1-R9050-D220-SW57-5700K-CRI92-LED-Emitter
Thanks
Ban
Ban , could you get higher bins of Nichia ?
For example Nichia 219C D320
Sure.
I would try to contact our supplier and see it is available or not.
Thanks
Ban
New KDLIGHT XP-16 16mm x 1.5mm DTP Copper MCPCB
http://www.kaidomain.com/p/S025781.KDLIGHT-XP-16-DTP-Copper-MCPCB-for-Cree-XP-Series-2pcs
CREE XP Series and NICHIA 219BT-V1 LED with KDLIGHT XP-16 DTP Copper MCPCB
http://www.kaidomain.com/Search/SearchResult.KDLIGHT%20XP-16
Thanks
Ban
Will this come back in stock ? :
http://www.kaidomain.com/p/S025100.Cree-XHP35-HI-E2-3C-Neutral-White-5000K-LED-Emitter
The 5700K 9050 Nichia 219B is the first of this type that I have seen, very nice! Myself I like warmer tints but I know there are quite some people on BLF who like high Kelvin high CRI leds.
Some 92 CRI in warmer tints would sell like cake !
Hi khas,
I am sorry CREE XHP35 HI NW LED is still not in stock.
Best Regards
Ban
Support @ kaidomain.com KD
New Cree XM-L2 U4 0D 7000K - 7500K LED Emitter
http://www.kaidomain.com/p/S025888.Cree-XM-L2-U4-0D-7000K-7500K-White-LED-Emitter
Thanks
Ban
Just noticed these, great product to have! Now it would be good to start selling some of the most popular emitters already soldered to them
edit: just noticed that you already sell them mounted! I never saw them because I only search under “LED emitters” and not under LED stars
Is this data correct?
