M4D M4X deals - Astrolux WP1 and WP2 LEP
Any codes for the Nitecore SC2 charger?
Hi Martin
Any codes for a Thrunite TH20 headlamp?
Thanks
i asked
Nice and useful mod. Thanks for sharing.
new codes arrives for:
Nitecore CI6
CREE XP-G2 440LM Chameleon Series Tactical LED Flashlight
-> limited €U stock with great price!!!
Klarus ST15
CREE XP-L HI V3 1100LM Classic Tactical Setting LED Flashlight
af first a goodie:
astrolux S3 (my Link) ef5700 $ 22.75 PRICEDROP
finally on stock :)
Lumintop SD4A 1000LM LED Flashlight
CREE XM-L2(U2) OR CREE XP-L HI
great deal – ask for details
Product name: LUMINTOP SD4A CREE XM-L2(U2) And CREE XP-L HI LED Flashlight
Total Emitters: 1
Emitter Brand CREE
Emitter Type: CREE XM-L2(U2) / CREE XP-L HI
Max Lumens: SD4A-XML:1000LM
SD4A-XPL: 920LM
Intensity: SD4A-XML:20300cd
SD4A-XPL: 40000cd
Peak Beam Intensity: SD4A-XML:285m
SD4A-XPL: 400m
Mode: 8 Modes(Low-Mid-High-Turbo-Moonlight-Aviation Signal-SOS-Strobe)
Max Runtime: 51h
Battery Configurations: 4 X AA or 1X D Cell
Switch Type: Clicky
Switch Location: Side
Working Voltage: 0.9v-6.4v
Impact Resistant 1.5m
Waterproof: IPX-8
Weight: 178g(without battery)
Nice price on the S3!
Any code for imalent DN11?
there will be :)
Is the Astrolux S3 made by Manker? If so, presumably it won’t be available for much longer?
you may be right....
new Astrolux MH10!
presale start soon... ;)
Features:
1. Built-in temperature control module, automatically adjust the brightness according to ambient temperature working status of each output in order to achieve
the best working condition
2. Tip overheated housing
In the lighting state case temperature reaches 55 degrees, LCD display will flash rapidly to alert temperature symbol with dimming to ensure the user's comfort,
so as to prevent excessive heat generated by the discomfort.
3. Low battery indicator
when the battery voltage is lower than 3.1V, LCD will display (the frequency of 30 times per sencond), battery symbol flashes to prompt the user to replace the
battery or charge it in time.
4. Aerospace grade aluminum, Army regulations three hardened wear-resistant surface treatment
http://m.banggood.com/Astrolux-MH10-Cree-XPL-HI-18650-1000LM-USB-Rechargeable-Outdoor-LED-Flashlight-p-1064463.html
Which company is behind this ?
Thanks , i missed this thread .
Why? Has Manker’s deals with BangGood lapsed?
They stopped working together.
Any link to this info?
Getting “This coupon could only be used 50 times”.
new code...
01.07.2016 FL astrolux S2 deal531 $ 20,37
01.07.2016 FL astrolux S3 deal531 $ 23.80
01.07.2016 FL astrolux SS Stainless deal531 $ 47,57
