The Liquid Pro stuff seems to harden and stick after use, difficult to clean up completely if remodding the light in my experience. I’ve used it with some Sinner Cu EDC lights…everything there is copper so no issues.
I had two both from mtn so used what I had. The other is 20mm and using with 4 tube and heatsink added. Will switch to two tube when 26350s arrive. I had a supply of the spring inserts between batts and use them.
OK, now this makes sense to me. This is how I have been doing it, without knowing if it was the proper way or not. But if it is good enough for you DB…. it is good enough for me. :+1: …
My goal has been to be able to visually see a small bit of the thermal paste come out from under the edges of the MCPBC when I pressed it down. If there was ever an over abundance of paste I cleaned it off all the way around the MCPBC and pressed again till no more came out. Then cleaned off any excess and called it good.
I’ll just continue down this path as it seems to be working well for me.
Thank you for the info DB, makes me feel like I was doing something right.
I know a couple of factory lights I have just did not seem to be getting very warm / hot on Turbo mode. So I charged up the batteries and ran them on Turbo for a specified amount of time. At the end of that time I measured temperature in three places on the lights.
I then took them apart and checked to see how much thermal paste was under the MCPCB on both. On both of them the MCPCB was only about half covered with paste.
I reapplied thermal paste as described above to both lights and retested the exact same way. The temperatures measured in the exact same places on each light were all higher…. which told me the internal heat was being transferred better.
I know that is not very “scientific”, but does that sound like a correct assumption???
Yes teacher if only half is covered cooling suffers
Sometimes there is too much and just cleaning one side to remove about half is fine.
When removing a heatsink +or in this case a star, you actually want to see the metal and small ridges of paste from pulling the parts away.
That sounds right Miller, when removed it should look like there wasn’t enough. lol
I’ve opened many a light that showed clean copper under the mcpcb (or aluminum) and no paste ever touched the pill in that area. I’ve even seen more than I’d ever have thought with zip between em, nothing at all.
I’m a copper fanatic, I love putting copper under an emitter. If/when possible, I shove as big a piece of space filling copper as I can get between the driver and emitter. It’s been argued that what I do is overkill. That’s fine, that’s exactly what I want. I go to a lot of trouble making sure the light runs as hard as it can be pushed, so if I’ve got excessive sink under it, I’ve done it right.
Wauw the light is in France (I know checking tracking … :person_facepalming: )
Bit considered the price I kind of expect it to say Jax instead of Jaxman .
This is not all negative since I like Jax better then Jaxman bit begs the question, can I still talk about it in this topic?
Regardless of the Jax or Jaxman designation, it’s made by the same people, right? Paul and his team made em, the name only changed due to technical issues with registering the brand.
I guess Yourrid can chime in in his own thread and claim or reject the original Jax light as relevant here. That would solve all speculation (as regards this thread and it’s contents)
To my knowledge, Yourrid started this thread due to the Z1 thread being closed, a way for those that were building the Z1 from the host to still share their build for the rest that were interested. I would have assumed that The Miller or someone would continue the Z1 group buy. Shame for it not to continue, as it’s a really sweet little light and so well made.
I for one hope the GB moves forward. I have learned to appreciate this company, their products, and their efforts. We should at least try especially when the company is receptive. Let’s just do it!
Please do not let it colour your general attitude to this thread.
AFAIK, until now, you did not have an interest in this torch, but like to inform us of your opinions.
If I have misunderstood, please discuss this with me by PM.
I am pleased to hear that you have had a good dialogue with Jaxman, and expect that that will continue, whether or not this GB continues, despite the odds.
Yes do assume I will receive an older version, have talked to Tom E and the differences are minor.
I’ll let you guys know when it is in what was in the box
As far as groupbuy organising go, sharpie made it clear he likes to do it so like in the closed thread when something really needed attention I chime in and when he does take action it is all fine (and Sharpie has done so consistently)
So I am waiting on progress and know that Sharpie will inform when there is input to be shared.
I think that the received lights are build very nice and Paul could know now that people buying a host do know what they are doing.
Well he has said reading BLF is hard, not only because of language but also the Great Firewall plays a role. That some things go off topic or people can argue certainly will not help either.
But I trust Paul to be smart enough to see opening a groupbuy is a good thing since Jaxman delivers what is promised and buyers know what to do with the items. These two things are most important IMHO.
The set goal for 100 is tricky with a positive flow missing, the Z1 being a zoomie that tend to be less popular and ~$44 is a fair price it is by no means a very low price.
Seeing the cool things build, thanks to this new topic! Could bring more people on board.
But indeed Sharpie, please let us know what is the status and if needed hand things over to me I would not mind that.
All Jax/Jaxman/Jaxwoman Z1 discussions are welcome here :+1: . I have both, the Jax and Jaxman version, and there is very little different between. I think the knurling is slightly different, but unless you have one side-by-side, it would be hard to notice any difference. Both are extremely high quality. And the Jaxman comes with a lens cover, whereas the original Jax did not.
I definitely want everyone to post their builds and specs so onlookers can make an educated decision on which way they want to take their build. Even though the last thread got shut down, I’d like to see what everyone came up with.
Talking about having a group buy is 100% fine, but this thread isn’t going to become the group buy thread. If someone wants to start it back up, then they’re welcome to on their own thread. I’d be happy to include a link at the top for people to find it easier as well.
Hoop is making some centering rings for me in a few different emitter sizes, so as soon as I have them, I’ll be putting mine together. I think I may have a spacer that would work, but I sent my original Z1 spacer to him so he can measure it accurately for the spacers he is making for me. If I can find a spacer that will work, I’ll be putting my host together this week.
