Thanks texas. I doubt if I have an o-ring this size. Guess I could contact Manker for one.
This 27mm glow-in-the-dark o-ring fits great in the U11, if GITD is something you’d be interested in.
Cool. They’re blue too! Thanks!
Nice review buddy,planning to buy NW one.
Appreciate your nice review. Manker seem to be pushing the boundaries a bit. Interesting to watch and maybe buy at some point.
Thank you for the nice comments.
Nice tip.
i like it but
it is too big and heavy
my other EDC is a DQG tiny 18650, which has a completely opposite UI - hard to switch between the 2 lights
moonlight mode is too low
would like more evenly spaced [logarithmically] lumen levels
the charger is nice
the LED color is nice
the side blue LED ‘dragon mode’ is fun for about 10 minutes
this is hard to explain, but usually the reason for wider and longer heads is to get a more focused throwy beam
this is not throwy, it is semi-flood at best {which is fine for a pattern BUT…}
they could have made the light smaller if they were going to have that beam pattern
the DQG uses a very short TIR to focus the beam - and it makes the light about 10mm shorter, which is a LOT
these guys made a wide and long head but then orange-peeled it, wasting the focus and size
a lot of the other features [blinky modes, “super turbo”, light level programming] don;t really seem that useful after you see what they actually do
the light levels for instance, yes you can change them, but the levels you can use are not really what i want
also the turbo mode and super turbo are not very different from plain old ‘high mode’ with the batteries i use [cheap or laptop recycles]
i am not going to buy $20 batteries just to get 40% more light for a few minutes
wle
I have both the U11 and DQG 4th. Got the DQG first and it was my EDC until the U11 came along. I bought it based on positive reviews here (4wheeler’s included) and don’t regret it in the least. A good flashlight for the money.
The U11 carries deeper and has rounded edges which I find more comfortable. I like the larger switch too (the DQG’s switch is small) and its much brighter when needed. The USB charger is handy when traveling but I’ve only used it once and that was to make sure it worked.
All this said I’d gladly swap the UI from the DQG unto the U11. Much more intuitive for EDC use than the oddly organized UI on the U11.
The U11 is a good flashlight and I will EDC it again today over the DQG but the UI holds it back from greatness.
yes i would like to redo the UI also on the U11.
it annoys me that the thing has a USB port, and i KNOW that is how it is initially programmed, so you could redo it from there, but no one knows how.
i actually wrote to manker from their web site, and asked that - no reply.
wle
I'm ordering one from the US warehouse for $29.56 with freeme's code: MKU11. Shouldn't be a problem getting a Attiny85 driver in there. Planning on doing it to a T01 as well, and lot less space in the T01 from the looks of it. It's very similar to this light: http://www.gearbest.com/led-flashlights/pp_71296.html, which was and still is one of my favorite budget lights, but the U11 is a lot more quality. I got 85/Narsil on one of those Zy-T11 clones. My Manker U21 given to me by Manker for a review died, but it was a blessing in disguise - now it's throwing a lot further and more lumens with a dedomed XPL V6 0D and running Narsil utilizing the RED LED under the switch cover, and powered by a LK 5000 of course.
I've taken my T01 apart and appears to dis-assemble the same exact way as this U11. The U21 scales up from these designs with a separate USB charger board, but I tossed it.
I got my light, actually just ordered another. Wow, it's really a nice carry light/EDC. I got it all apart, as done here. Mine needed more help to get the pill out - it seemed like a tight press fit. I used a screwdriver and hammer and tapped all around the edge of the driver, around the spring.
I totally mis-judged the spacing from the pictures above. There basically is no room between the driver components and the shelf the MCPCB sits on. I don't think a piggyback board can fit in there with the stock driver stripped, even with the OSHPark thin boards. Ideally would be best for a driver board replacement, as ImA4Weelr shows. Securing the switch board though is the challenge, as well as getting a properly sized driver to file down and fit. I think it's do-able, but not easy, maybe not pretty.
Keep us informed. I’ve thought about this mod a number of times. But held back because of the challenges you describe. I think it is definitely doable though.
I spent some time on this over the weekend. I sanded down the outer pill surfaces to try and make the pill insertion/removal easier. I somewhat succeeded - it's easier, but I messed up the MCPCB shelf a little, but sanded it all down to smoother than it was, getting rid of the typical circular machine marks on the shelf surface.
I dremeled down a 20mm Noctigon to replace the poor stock non-DTP MCPCB of 1 mm thickness. The new Noctigon fits, can be screwed down with the stock screws, and is thinned down to 1.25 mm. Hope the 1/4 mm will do ok when re-assembled.
I really like this light but they went cheap with the pocket clip and MCPCB - these are not components you find on $60 lights, not even on most $30 lights. It's pretty ridiculous actually considering they are over-driving the light at 3.6A (over-driven for stock lights) and not using a copper DTP MCPCB. You lose a considerable amount of lumens and can't get the heat out, so thermal sag has to be killing what this light can really do - super thin non-DTP, cut down shelf, what were they think'n? Makes you wonder if they do this stuff intentionally to keep the light from getting hot in the hand, or are they just that cheap?
Still have to decide what LED to use - think'n of a dedomed XPL W2 1A, or least a V6, and/or possible domed NW XPL. Though it has a OP reflector, a dedomed XPL should still get some decent throw - a good downsized match up with the U21 I have now, dedomed, FET+1, Narsil that does ~240 kcd, 1,600+ lumens.
For the driver/electronics, for now will just try 22 AWG LED wire upgrade, bypass springs, and see how it does.
I do want to check some things out for driver replacement. Thinking a 20 mm driver w/trimming and attempt to mount the vertical switch board to it, stripping the electronics, but seeing if I can re-use at least the RED SMD LED's w/Narsil control. Best solution would be a custom laid out OSHPark board, though not sure if you can get enough precision for the vertical board mount - OSHPark tolerances aren't that good. I'll lose the USB charging, but no great loss.
I took pics, hopefully will post them up soon.
Edit: Here's my break down and mods so far. Didn't get the LED mod done yet:
I trimmed down a 20 mm Noctigon to fit (rotary tool w/sanding drum), using the soldered on wire to hold it to sand down the thickness to get close to the 1 mm thick stock MCPCB:
Before:
After:
Sanded down the shelf. I mangled it a little while trying to manipulate it with heavy needlenose. This pills fits very tight in mine. The surface scratches and mangled edges are all sanded down so not much interference with the MCPCB mounting. Probably a better bond than it was stock with the circular machine marks, still showing on the outer edges:
Pretty much perfect fit now. Had to extend the wire cutouts to get the screws to fit well, and with the cut top, the wires can pass thru as before. I'll probably angle file the edges of the PCMCB at the pads in order to avoid an erroneous contact with the pill housing:
I finished the mods for now, stock driver, stock XPL V5 1A version:
- Before, stock on SANYO GA full charge: ~3.5A at the tail, @start: 1,139 lms, @30 secs: 1,088 lms, 16 kcd (taken at 5m) for 253 meters
Mods: XPL V6 3D on 20mm Noctigon, as shown above, filed down to ~1.25 mm thick, trimmed to fit, GC Extreme under the MCPCB, thermal grease on the outside of the pill, cut down the 24 AWG LED wires to min length, driver spring bypass and tail spring bypass w/22 AWG wire
- After mods, on SANYO GA: 3.46A (@tail w/clamp meter), @start: 1,221 lms, @30 secs: 1,159 lms, 17 kcd (taken at 5m) for 261 meters
Also received my 2nd U11 from GearBest. This one had the smooth bezel (no notches), added a LED centering piece, different body design w/slight differences, different finish - flat black and not glossy black, and the biggest problem was the missing screws holding down the MCPCB, probably having the direct result of a large output droppage in the first 30 seconds.
- Stock on SANYO GA full charge: ~3.62A (@tail w/clamp meter), @start: 1,088 lms, @30 secs: 959 lms, 14 kcd (taken at 5m) for 237 meters
Here's what the #2 MCPCB looks like:
Well, think the droppage is fixable, like I did with the first one.
Amazing mod Tom. Thanks for showing. :+1:
Thanks, but I always seem to miss taking the final assembly pics - I get so excited and impatient at the end, I forget to take them.
Nice mod Tom. I have some limited resistor mod info in Post 7 above if you decide to stick with the stock driver.
Considered it, but making the top 3 modes the same max level doesn't sound good. Was think'n of experimenting with resistor values, but for one - it's in a nasty spot, plus it's already a pretty small value - don't have resistors to use. I'm still going to do more research on mounting a replacement driver when I tear down the 2nd piece.
A world class Tom E momentary UI would definitely take this light to a whole new level.
Personally, I would toss the USB port. I don't like how they make lights vulnerable to water/contaminants. I've been playing with how to cover the remaining hole. Leaning towards screwed down plate, maybe with a leather inlay.
Yea, the USB port goes, no doubt. I'm not crazy bout leaving it there as well, but what I've done before is use JB Weld to fill the hole, but it would look ugly if I remove the rubber cover on this one I'd think, plus the color and fill of JB Weld would not come out look' good I'd think.
