FX35 and xhp35 P2 1C Sinkpad using single Thorfire 5000 protected: lux; 118 / 669 l/h/strobe; converted same parameters as OP lumen 551 / 3124. Focus just short of. Yellow dot center. Yellow ring outer. offtopic: I am eyeing, budget permitting, a mirrorless Sony A6000. Very aware that pics are mandatory. Any thoughts?
A single protected cell for a boost circuit, sounds like you’d be better off with an unprotected high discharge cell.
Will change cell to BASEN unprotected. Thanks for the input.
Fresh 4.2v BASEN 4000 checked at 583.72 and 3203.49 a difference of plus 31-32 lm on low and plus 79 lm on high. The order is h/l/st. Seems quite consistant for a 1A (1.5A max) driver. The mtn 22mm 4s was ordered 2.5A (NTE 4A led)
My XHP-35 at 2.89A is making 2300 lumens, wonder why your numbers and mine are so divergent? I’m using 4 18650’s on the second one, 4 18500’s on the first one, both are running modified led4power LD-2 drivers.
The 2.89A one is a MaxToch Shooter 2X, amps measured at the emitter.
Well strictly speaking a professional is someone who gets paid whether they’re well trained or now
I’m also interested in the stock Z1 with XHP50 emitter, but only when using 2x 26350 batteries as I’m not fond of the extended length of 2x 26650 as I do find the size of the “pipebomb” feels just nice in the hand.
But so far only one member has tested the Z1 XHP50 with 2x 26350 and his initial impressions on the config is not that impressive, so I’m reading this thread on what are the options available
I did resistor mod in the meantime. It doubled the tailcap Amperes and got the light A LOT BRIGHTER!
Look here for more information: Z1 resistor mod
Hi, I did the resistor mod on the stock Z1 XHP50! As I only had a R100 at hand this was added to the original R150, giving a total of 0.06 Ohm instead of 0.15 Ohm on high.
Will that location be real obvious when I look at the driver?
The only input I can give is driver design differences. Without tearing it down I do remember he swapped the coil to small fine wire wrapped sealed type versus coilcraft (4s). The FX uses a huge coil (coilcraft type clone) 1R0 111 TB9. I’m looking at the 111 as a ratio. The 4s mtn I recall a very large R050 installed. Sorry I can’t be of help. I don’t know.
I took a picture for you where you can see the stacked resistors. There are one R150 and one R160 side by side, the R150 has my added R100 sitting on top
Thank you for the picture…and lol at “Gyro Gearloose”
I’m ordering a MTN Max buck driver (2.5A) to run an XHP-35 hi in this light, but I’m torn on which driver program to order.
The guppydrv is what the cats meow, but it doesn’t come with low voltage protection, not that I ever run my cells down too far, but with 4S unprotected it might be wise.
That leaves me with MTN standard moon, low, med, hi, or custom, not sure which way to go. I don’t really think moon is that applicable to this light though.
With guppydrv, I can set the turbo timer myself, but with the MTN standard, I’ll have to preselect, which is another dilemma since I have no idea how this light handles the heat.
Any thoughts?
Custom, pick your own levels, 60 second Turbo timer (for safety) you can alway’s kick it back up and the LVP. :+1:
Not having any real experience with zooming lights, I’m not really sure what mode settings are best for a light like this, and which ones are rarely used. Obviously, it doesn’t function, or is designed to perform like a standard reflector flashlight, so I’d like to get the custom modes
just right.
Something else to think about… :person_facepalming:
CUSTOM: Choose your own modes (please put desired modes in checkout comments)
1 to 6 modes
Ascending or descending mode order :person_facepalming:
Memory: (n/a for guppydrv)
Yes: remembers last mode.
No: always starts in first mode :person_facepalming:
On the XHP35 @ 2.5amp - 2000lumen there about, base your choices on what levels you would want for your use? Indoor/outdoors? My big lights I don’t need a going to the out house to pee level and would mostly be used outdoors in cooler weather, and I carry a smaller light for navigating at night, so I keep the levels towards my intended usage, XHP35 I like 25% (500lumen low) 50% 75% 100% the XHP70’s 5000+ lumen 10(500lumen low) 30%70%100 I like having the memory for outdoor spot/search/hunting lights so I can keep it at the Turbo level for scanning on/off, while on stand or in my hide,usually over an open field or in light to heavy woods to brush I can use the lower level for on/off scanning. But this works for me, it is what I like, from my experience’s in the field!
Every light I build gets guppydrv v2 no matter what. I almost have all of the modes memorized now haha!
I’m a little OCD about keeping my lights charged. I literally have to use my charger to cycle them every now and then because they never go bellow 50%.
I think it depends on what you’re going to use it for. If was going to use a light for a camping weekend, where I may need to use the light until it dies… then I’d definitely pick one with low voltage protection.
Yes. That’s what I mean. It’s not really a light meant for taking the dog for a stroll in the park, so I didn’t really think the lower modes would get a lot of use, just modes to skip past.
Why isn’t it a stroll-in-the-park light? The zoom feature allows a beam pattern for what you wish it to be. Wide angle flood for a walk, zoomed in hot spot for a shot at game or searching for the dogs lost ball under the brush.
Moon is nice with the wide angle, for a great many purposes. Not so much the zoom tight beam which is where Turbo comes in.
Leave yourself options. Then you can explore how the light works and set it up accordingly.
Now I’m getting really confused, but you’re right, since I’ve never really used a zoomie, I should keep all my options open. These drivers aren’t cheap, so I better choose wisely.
