Yeh, a round 4x1mm magnet superglued does it. Center magnet and apply glue ONLY to perimiter of magnet NOT under it. Glue does not conduct.
I have had magnets superglued to flat top pulls for 5 years now and no problems whatsoever.
“Sir headlight”…… all 6 of your LittoKala 26650’s work in series??? I have 4 with 4 more on the way. None of the first 4 work in series at all. :person_facepalming:
I wonder what the differences are??? ( besides the obvious of course )
Hmmmmm… ??
Ordered yesterday from GB. Showing already shipped via Netherlands Post. I expect receipt in about 6 weeks
I plan to use them in my L6 that should arrive any day now.
No idea what if any difference there is teacher but they definitely all work in both my S70 & Z1 XHP 50 (the only 2 x 26650 lights I have).
To look at the cells you wouldn”t think that they would work in series without a magnet or such like as the tops are very flat & I am surprised myself that they do.
That is certainly interesting. I look forward to seeing if my next 4, that are in transit now; will work in series.
Thanks for the info & ‘consumer report’ bella-headlight………… :+1: …
On the +ve side or -ve? Tradition would say on the +ve to make them feels like “button top” but I see advantages of placing them on the -ve to protect the bottom plate from sharp tail springs of certain flashlights.
So, wait a minute… Are there two versions of this battery? On Ali they are listed as 50A batteries and gearbest states they are 20A. Has this been discussed already? Sorry if so…
I am waiting on these batteries, but from the photographs they look like these would not be a good candidate for using in series. I plan on using mine in my single cell lights.
I am waiting too on the Convoy L6 but plan on using Shockli 4200mAh batteries; they are flat-top batteries with the positive terminal high enough for good contact. Not all flat top batteries can be used in series because of a shallow positive terminal.
Oh man! I totally forgot about ordering two from AliExpress and they arrived today.
Since I was no longer aware they were coming I thought Gearbest f#*ked up LOL
They are on the charger now but when done I will compare them to yours Teacher (seems like I’m the only having them from AliExpress)
Hmm 2 heters 6 littokalas 1 On The Road 1 OrcaTorch = 10 (and a poor Ultrafire only used in testing)
Permanent in use 4 (L6/S70)
Nice to have loaded OrcaTorch and On The Road X5, Convoy BD01 and BD06.
I got two too much. Well one for the Z1 instead of high drain Keep power.
OK 1 for another MTG2 or Luminus SST 90 modded Z1. OK I am good, thought a sec I needed a new light
Just got my pair today from GB, first discharge test with my MC3000:
Discharge rate 1A, down to 2.75V with termination current 0.2A:
Batt #1 5,128mAh
Batt #2 5,210mAh
Great capacity and consistent IR. They DON’T work in series no matter how much pressure I put on them. This is the shortest 26650 cell I have, about 3mm shorter than a button top KK.
For the current price this is the highest capacity/dollar cell in any format!
Mine are the same except for the last 5 digitsof the lower row
08344 for the 5428mAh one
and
20776 for the one still testing
I saw it stop the discharge test at 2.8V.
An overshoot of almost 10%, I only hope the other ene gets close or this first one is a Convoy filler. (And still no decent cells to fill both L6 and S70 with now.)
But IDK, the one tested came at 3.8V and the other 3.4V, and well it had to charge 0.4V more is now on 3.4V going down,
Was the test done in a Opus? I think the it throws a higher than actual reading when doing discharge tests, when I had my C3100 v2.2 a samsung 30Q yielded almost 3,100mAh which is unrealistic, the same cell in my SkyRC tested less at 2,890mAh even when a lower cutoff voltage and termination current was used.
I could test again down to 2.5V and at 500mA rate, probably about 50-100mA additional can be extracted but I’m not sure about how far can this cell be safely discharged.
I have one of those 1 bay Opus chargers that got good reviews, don’t like it, with this warm weather it gets too warm
Just love my Liitokala
(Though even when that is not as warm as the Opus it still is warm with 27°C where I use it so I hook up two small PC fans (1/underneath and 1 blowing over the cells with a piece of 10*10*0,8cm copper resting on that tiny fan and the cells))
