That is certainly interesting. I look forward to seeing if my next 4, that are in transit now; will work in series.
Thanks for the info & ‘consumer report’ bella-headlight………… :+1: …
On the +ve side or -ve? Tradition would say on the +ve to make them feels like “button top” but I see advantages of placing them on the -ve to protect the bottom plate from sharp tail springs of certain flashlights.
So, wait a minute… Are there two versions of this battery? On Ali they are listed as 50A batteries and gearbest states they are 20A. Has this been discussed already? Sorry if so…
I am waiting on these batteries, but from the photographs they look like these would not be a good candidate for using in series. I plan on using mine in my single cell lights.
I am waiting too on the Convoy L6 but plan on using Shockli 4200mAh batteries; they are flat-top batteries with the positive terminal high enough for good contact. Not all flat top batteries can be used in series because of a shallow positive terminal.
Oh man! I totally forgot about ordering two from AliExpress and they arrived today.
Since I was no longer aware they were coming I thought Gearbest f#*ked up LOL
They are on the charger now but when done I will compare them to yours Teacher (seems like I’m the only having them from AliExpress)
Hmm 2 heters 6 littokalas 1 On The Road 1 OrcaTorch = 10 (and a poor Ultrafire only used in testing)
Permanent in use 4 (L6/S70)
Nice to have loaded OrcaTorch and On The Road X5, Convoy BD01 and BD06.
I got two too much. Well one for the Z1 instead of high drain Keep power.
OK 1 for another MTG2 or Luminus SST 90 modded Z1. OK I am good, thought a sec I needed a new light
Just got my pair today from GB, first discharge test with my MC3000:
Discharge rate 1A, down to 2.75V with termination current 0.2A:
Batt #1 5,128mAh
Batt #2 5,210mAh
Great capacity and consistent IR. They DON’T work in series no matter how much pressure I put on them. This is the shortest 26650 cell I have, about 3mm shorter than a button top KK.
For the current price this is the highest capacity/dollar cell in any format!
Mine are the same except for the last 5 digitsof the lower row
08344 for the 5428mAh one
and
20776 for the one still testing
I saw it stop the discharge test at 2.8V.
An overshoot of almost 10%, I only hope the other ene gets close or this first one is a Convoy filler. (And still no decent cells to fill both L6 and S70 with now.)
But IDK, the one tested came at 3.8V and the other 3.4V, and well it had to charge 0.4V more is now on 3.4V going down,
Was the test done in a Opus? I think the it throws a higher than actual reading when doing discharge tests, when I had my C3100 v2.2 a samsung 30Q yielded almost 3,100mAh which is unrealistic, the same cell in my SkyRC tested less at 2,890mAh even when a lower cutoff voltage and termination current was used.
I could test again down to 2.5V and at 500mA rate, probably about 50-100mA additional can be extracted but I’m not sure about how far can this cell be safely discharged.
I have one of those 1 bay Opus chargers that got good reviews, don’t like it, with this warm weather it gets too warm
Just love my Liitokala
(Though even when that is not as warm as the Opus it still is warm with 27°C where I use it so I hook up two small PC fans (1/underneath and 1 blowing over the cells with a piece of 10*10*0,8cm copper resting on that tiny fan and the cells))
HKJ wrote in his review the IR is not good.
I push cells up to disconnect and see it a couple of times
then go with the lowest and some cells are gradually getting higher (the ones I use for testing now that it is all lights with build in chargers)
Second done
5401
5428 11mR
5401 12mR
Ah nice, these seem close enough to put in the L6 then.
I use my chargers that give internal resistance and other parameters as mere guide lines; I would not expect a plus $30 charger to give accurate results.
I do use the results found by chargers like Opus as a way to match batteries that are used in series.
Good solid results IMO, within 100ma of each & similar IR.
I think that your charger is exaggerating the ma”s a little but as long as all 6 cells are analysed on the same charger that is not a problem.
My 6 Liitokala”s gave very similar results, all within 100ma of each other & all with consistent low IR”s on my Li-500 engineer.
These have to be the best performing unprotected 26650 cells around at the moment & only $20 for 4
