FWIW, surplusshed.com has a Jaegers 41mm diam., 35 mm FL for 4.50 US, a Pyrex 44mm diam., 30mm FL for 6.00 US, and a double convex aspheric 44mm diam. 30mm FL for 5.00 US. Shipping is a flat 5.00 for an entire order. More expensive than some, cheaper than others, somewhere in between. Probably good quality; I don't have any of the three myself.
I'm only getting ready for my first aspheric mod, but I think the flange makes the job much easier. I also doubt if a double-convex lens would be suitable for this task.
Yes, they do have a flange, which should make grinding to size somewhat easier. I agree about the DCX, although someone in another thread (I haven't searched for it) did use a DCX successfully.
"For shipments going to Hawaii, Alaska or countries outside the U.S., we will e-mail shipping option prices for your approval prior to processing your order " This what they say about shipping outside the US.
The best way that I have found is to use a conventional bench-top grinder, resting the lens flat side down on the provided support in front of the wheel,with a piece of thin cardboard under the lens to prevent scratching. I bring the lens against the wheel and rotate it horizontally as methodically as I can to try to maintain a circular shape. A fairly slow process but not too bad; nonetheless,I hope someone has a better way.
ChicagoX, thefirst one (Jaegers 41diam./35FL) has a back FL of 30mm, 15mm center thickness,3mm edge thickness. For the second (Pyrex 44diam.,30 FL ) no back FL given,14 mm center thickness, 2.5 mm edge thickness. The last one, the DCX, again no back FL given, 17 mm center thickness, 3 mm edge thickness. All this from their website, again, I don't yet have any of them. Given the $5.00 flat rate shipping I may order all three for 20.50 rather than one for about 10.00. Spend money to save money.
I found dremelling to be very very slow, but I think it would have worked if I was more patient. The grinding wheel does create excessive heat if the lens isn't kept moving or "backed off" periodically.
I had no previous experience either. It turns out that glass is fairly soft so no issues with cracking or chipping.
My main concern was (as is) to wear a mask and to use the grinder where you can clean up the area easily. Keep the area around it clear so that powered glass dust don’t get on things.
My main concern was (as is) to wear a mask and to use the grinder where you can clean up the area easily. Keep the area around it clear so that powered glass dust doesn’t get all over everything. I wouldn’t want this dust in my lungs either!
