I think you got a lemon because not as bright as 500 lumen lights would mean 400 lumen or so. The Mi7 should have about 550-600 lumen according to many other tests here.
Very possible. I can only go by the one I recieved . It seems to work nomally. No flicker, modes work normally, etc. My 14500’s work perfectly fine. What else can I say?
2 reviewers have measured the light at over 600 lumens. It should be brighter than your 500 lumen lights unless you got a lemon.
Also it still sounds like you’re comparing brightness by looking at the hotspots. This is NOT how to do it. You need to point the light at the ceiling and look at the reflected light at the floor… or use an integrating sphere. Hotspots alone can be very misleading. For instance, the Klarus might have a smaller dimmer hotspot and yet still be brighter than your 500 lumen lights due to wider spill. If you’re trying to measure total lumens produced by a light you cannot look directly at the hotspots.
It’s also possible you got a lemon. My recollection is that even with the same brightness bin there’s a +–20% brightness range. It’s possible your Klarus just happens to be at the bottom of that range while your 500 lumen lights are at the top.
A third possibility could be your cells aren’t high enough quality or are too old to get maximum output. I don’t have this light myself, but my favorite 14500 cell is the Efest purple IMR from Mountain Electronics. With one of those in my modded 1xXPL HI Skilhunt DS16 with FET driver and my light is as bright as my SC600w III HI. So well over 1100 lumens for a brief period of time.
The Op says it’s not kickin out the light it should. I tend to trust folks on this forum and Klarus tends to overstate lumens anyways. The g30 puts out 1900 from a claimed 2450. I agree, wait til folks get the G20, there’s gonna be a s$&tstorm!!
Look guys, I’m not a newbie with flashlights. I have around 50 over the course of the last 5 years and never been more disappointed. I don’t care what ceiling bounce might say, I go with what my eye says. And it say’s this thing sucks. It’s true my particular Mi7 could be on the lower end of the scale when it comes to output. But that’s how I’m judging it. That being said, I’m not a happy camper. That’s all I can say. Buy one at your own risk.
Glenn
Edit: someone marked this post as rude? Who ever it is, get a freaking life!
I guess nobody has an accurate sphere here but you can take other lights to compare with from the home made sphere. For the GB price this is probably the cheapest and brightest AA light you can get. Is there even a brighter 1xAA light? I mean we are talking about a keychainlight price and it even offers lock out and battery checker. Even with 550-600 lumens it makes sense to buy it.
Ok, but i guess not much more and that thing was designed for unprotected high drain 14500IMR batteries, its also much thicker and more expensive. The Klarus is for normal protected 14500 batteries. The nitecore is also much dimmer when using eneloops compared to the Mi7.
Actually I think it’s a defect only present in some EA11 samples. I saw people reporting the same problem on CPF. Some had the problem some did not. Also my EC11 and EA21 do not have the problem.
[quote=atbglenn]
Look guys, I'm not a newbie with flashlights. I have around 50 over the course of the last 5 years and never been more disappointed. I don't care what ceiling bounce might say, I go with what my eye says. And it say's this thing sucks. It's true my particular Mi7 could be on the lower end of the scale when it comes to output. But that's how I'm judging it. That being said, I'm not a happy camper. That's all I can say. Buy one at your own risk. Glenn*
I received the Mi7 from atbglenn over a week ago. I have to concur with him. The light is putting out maybe 300-350 lumens at best on AA/NIMH/or 14500. I Dont believe it recognizes a 14500 battery. IT IS DEFECTIVE. I contacted BangGood and after 3 back and forths, instead of replacement they want a Video. They have the original order # and understand that the light was sent from him to me, yet seem to doubt the word of two fairly experienced flashlight people from a reputable flashlight forum. Both of us have been around going on 5 years. However BanGgood resolves this is up to them. I refuse to make a video of a defective light. It would take an integrating sphere to get them to believe us. So Banggood, do as you see fit. I don't know how I could better convey to you that this is a defective light. The OP deserves a replacement.
[quote=atbglenn]
is not neccesary a sphere. I think with a luxmeter will be enough for see if there are the same output on the center of the beam with NimH and with 14500…
Point is, I’m tired of Banggood assuming people are stupid. To the general public, maybe that is the case. But on BLF, most of us are in the know.
Send out a light that is proclaimed to be puttin out a conservative 550 lumens is one thing. But 300-350 is UN-Acceptable Yes, 14500 yields maybe @ one hundred more lux than NIMH…but the total outut is still @300-350 lumens. This sample Mi7 is clearly a DUD… I don’t need the hassle of assembling a film crew to produce a video to prove that. It’s the principle of Banggood doubting buyers reports. Especially since this is BLF forum and the OP and I have been around going on 5 years now.
ETA: I won’t be commenting any more on this as it’s a souring experience. Through 4 exchanges, the ball is now in BG’s court. Some of you may say I’m not playing by their rules by not sending a video. If that’s the case, read the first paragraph above again
Banggood is a store. They request a proof for not normal functioning…of course is a is a hassle, but is necessary.
Not every body is a good person and many people try to take advantage, they can not trust (of course I’m not talking about you, I do not know you). And the time it takes one on a forum is not a sign of anything. We must be realistic and not get angry …
