Very cool! So there are enough threads in the head to continue twisting til stopped by the pill? I always prefer these kinds of lights without branding as well.
Enough threads for the pill to be screwed out about 8mm. Screw it out longer and the inner tube’s threads pop out. The pill is pretty close to the lens too, I don’t wanna be scratching it by hitting it with the pill. 8mm is about right, makes for a pretty wide flooder.
Very nice mod Mike. It’s a great and versatile flashlight. I never thought I would like it so much but nowadays it’s my favorite one. Great work.
How far can this light throw with 12 x 7135 chips Mike?
Good mod.
But If I understood right you loosed full focus(zoom in) mode? Now you have flood light?
Also if my memory serves me right in this light you have greater flood mode by dedoming emitter (try this).
This is thrower flashlight so it would be really nice to see throw numbers with classic nichia and your driver.
Wauw!
What smart clever solutions
Up side down switch
Getting the led closer to the lens.
Yes I have some contact with Martin too, excellent English AMD fast replies.
Anxiously awaiting if your suggestions can be done.
Yeah, I really like it with the wider flood. The waterproof rating is good for us cavers. Your switch mod that pointed me in the right direction, so thanks for the write up you did on it
I haven’t tried. I’m using Nichia 219c with dome intact. It’s a very nice tight beam, I haven’t tested throw distance.
No, that’s the beauty of this mod, full focus is still intact. With the pill extended out I can still twist it all the way in. So I have extended flood range but full focus is intact and untouched.
I have never seen a good tint after any de-dome with the de-domes I have tested. I really want to keep the 219C tint and CRI intact, it’s very important to me.
I’d like to know them too, but I don’t have the equipment to test. Maybe I should get it as I am selling lights to friends. What equipment do you recommend?
Thanks! About the mods, kiriba-ru might be able to make custom copper pills that are already extended, so there could be two ways to get it done. I’ll ask Martin by email tomorrow in any case.
Does the tail cap screw on if you screw the pill back in?
Got a link to any pages of caving pictures and stories? I did a lot in the US when I was a youngster. I miss it.
“Mr. Ranger, how many miles of the cave haven’t been discovered yet?”
I did this with an sk98 a while back. I filed down the end of the pill to get the emitter closer to the lens. Then I added the extension to allow the zooming mechanism to slide fully back.
It worked well. Gave me just over focused when zoomed in and a nice wide flood when zoomed out.
Nice mod! A wide flood is very useful and not many zoomies have it.
The Kan28 is actually a switch that I tested: switch tests: KAN-28, update: stock switch UF-1405 in post#12
No, not quite. It looks like it’s almost in but it doesn’t make contact. Need the original tail cap if the pill is in it’s original spot.
Not much caves lately, but I got some photos I’ve taken down in old abandoned mines. check my photo stream on flikr for tghe latest: Akrylamid | Flickr
Some older: Mine II 03 | A Gruvtroll (mine troll) in his natural habitat… | Akrylamid | Flickr
And my absolute favorite photo I’ve ever taken so far:
I’ve made two video clips too:
Looks nice. I found a spacer for my pill in the plumbing section of a “home depot” style shop. Not a perfectly tight fit but it does the job, I can screw the pill tight on to it and it fits back down into the outer tube:
Thanks!
And thanks for the link to your test. It looks like a good enough switch to use, it will make building these lights even easier then
I suppose you could also buy a spare pill and put an 8 mm spacer under the Noctogon. Then it’s just a pill swap to get either type of beam(more flood or more throw) rather than dedicated take tail caps which aren’t as readily available since they sell spare pills but not spare tail caps.
“I’d like to know them too, but I don’t have the equipment to test. Maybe I should get it as I am selling lights to friends. What equipment do you recommend?”
10-30$ China lux meters should be ok for getting throw figures. Couple of threads about them on BLF search box but if I remember right you can’t go wrong with any cheapo luxmeter.
So you are pro photographer?
I am looking forward for pics in zoom in an zoom out mode
Your 12x7135 driver would be killer for old and unavailable xp-g2 s4 2b dd emitter cause in FET driver it draws about 4.2-4.5A giving around 300kcd in throw and also very fine and most intense flood mode in a zoomie world.
But since you are not candela hunter this will also be fine. :+1:
That’s the thing with my tail cap mod, I don’t have to screw the pill back in. I keep it 8mm out and it goes all the way in when I twist the tube for focus, there is enough threading on the inner tube for that. I don’t shift focus range, I only add range to flood. Full focus is same as stock. By reading others comments it appears that the Kan28 switch fits in the cradle without modding, so all I have to do is the “spring extension” mode, and that’s as easy (if not easier) than adding a 8mm spacer under the LED PCB.
I think I have one laying around. One I bought some time ago but haven’t tested it even once.
Definitely not pro. This photo is taken with a zoomie. Flood beam for the foreground lighting, then I ran to the back and light up the side with focused beam:
I might become a candela hunter yet, if I could get my hands on one of them old XP-G2s you mention I might get hooked. I am going to build a B158B with a XHP35 HI though, have to try it out with my F-8 with zener mod. F-8 has 8 x 7135s and a FET on a 17mm driver board.
Wow what a interesting pic man!
OK today I am emailing with Martin about testing of their new 18650 cells
LOL one is now double charging (so with a USB cable direct and a charger. This was kind of exciting to do because Brinytes engineers could not say much more then “don’t do it, maybe the charging circuit fries and burns” so needless to say all progress was followed closely.
But I brought this topic to Martins attention. He is going to forward the information to the engineers, and sure Mike, if you mail him with more details they will consider it very seriously (I mean you just improved an already sweet zoomie so why wouldn’t they )
Is this b158b host available for purchase?
Yeah, I promised Martin I would send him the link to my first build with impressions, so I’ll do it today even though you have, and suggest a B158C
Yes. I sent an email to an email adress I found on Brynite’s website and asked. I was contacted by Martin, a very good person to deal with. He can be reached at ledflashlight@brinyte.net.
Hi Mike ,
You have done a great job. It has drawed our boss’s attention, I will translate the entire article to my boss and engineers and wait to see whether there will be any change in our future flashlights.
You know we really have a short product line on photography light on land, even we have several photography flashlights for diving, but we really have no such a flashlight which is used in photography on land.
You showed us a direction of how to design our next flashlight. We will take in some of your experience.
Thank you for your advancing spirit and effort.
