Test/Review of MecArmy 18650 U18-34 3400mAh (Black-red), usb rechargeable
Official specifications:
  • Type: Battery
  • Brand: MecArmy
  • Rechargeable: Yes
  • Protected: No Wrong, it is protected both over current and low voltage, I did not check over charge
  • Capacity (mAh): 3400mAh
  • Voltage(V): 5V
This looks like a standard LiIon battery, but it is a bit special, it has a build in charger.
Discharge curves looks good, with fairly nice tracking. The over current protection kicks in at both 7A and 5A.
At 5A the battery gets warm, the over current protection may be some of the reason for that.
At 7A the over current protection trips before the cell gets warm.
Here I have used the build-in usb charger to charge the batteries, charge current is about 0.5A. As is usual the case with charge chip there is some variation in charge voltage and the batteries stops at slightly different voltages.
The charge time is a bit long, being about 8 hours.
These curves are made after I charged the batteries with the build-in charger, as can be seen there is not much difference in capacity, due to the difference in charge voltage.
Conclusion
Interesting idea to build a charger into the battery and very practical if you carries something with only one 18650 cell, it can be charged from a phone charger, from a PC or from a power bank.
I only see one disadvantage with the battery: The size, it is a very long 18650 battery and not much equipment will be able to handle that long size.
The performance of the battery is good and the current limit will protect the battery from mistreatment.
Notes and links
The batteries was supplied by Gearbest for a review.
Compare to 18650 and other batteries
Interesting concept.
Did you check below the wrapper?
Got Brinyte cells in with same features.
Same plastic packaging (without information just the packaging)
Same little holes in the top for charging status LEDs.
Same button
But a silver wrapping so the green Panasonic cells used can be seen.
Testing them (crudely compared to you of course :wink: ) now
Little less then 3400mAh
Running them down so to do a charging with a cable plugged in
A very nice disassembly of the battery is posted by HKJ here
