No, not quite. It looks like it’s almost in but it doesn’t make contact. Need the original tail cap if the pill is in it’s original spot.
Not much caves lately, but I got some photos I’ve taken down in old abandoned mines. check my photo stream on flikr for tghe latest: Akrylamid | Flickr
And my absolute favorite photo I’ve ever taken so far:
I’ve made two video clips too:
Looks nice. I found a spacer for my pill in the plumbing section of a “home depot” style shop. Not a perfectly tight fit but it does the job, I can screw the pill tight on to it and it fits back down into the outer tube:
I suppose you could also buy a spare pill and put an 8 mm spacer under the Noctogon. Then it’s just a pill swap to get either type of beam(more flood or more throw) rather than dedicated take tail caps which aren’t as readily available since they sell spare pills but not spare tail caps.
“I’d like to know them too, but I don’t have the equipment to test. Maybe I should get it as I am selling lights to friends. What equipment do you recommend?”
10-30$ China lux meters should be ok for getting throw figures. Couple of threads about them on BLF search box but if I remember right you can’t go wrong with any cheapo luxmeter.
So you are pro photographer?
I am looking forward for pics in zoom in an zoom out mode
Your 12x7135 driver would be killer for old and unavailable xp-g2 s4 2b dd emitter cause in FET driver it draws about 4.2-4.5A giving around 300kcd in throw and also very fine and most intense flood mode in a zoomie world.
But since you are not candela hunter this will also be fine. :+1:
That’s the thing with my tail cap mod, I don’t have to screw the pill back in. I keep it 8mm out and it goes all the way in when I twist the tube for focus, there is enough threading on the inner tube for that. I don’t shift focus range, I only add range to flood. Full focus is same as stock. By reading others comments it appears that the Kan28 switch fits in the cradle without modding, so all I have to do is the “spring extension” mode, and that’s as easy (if not easier) than adding a 8mm spacer under the LED PCB.
I think I have one laying around. One I bought some time ago but haven’t tested it even once.
Definitely not pro. This photo is taken with a zoomie. Flood beam for the foreground lighting, then I ran to the back and light up the side with focused beam:
I might become a candela hunter yet, if I could get my hands on one of them old XP-G2s you mention I might get hooked. I am going to build a B158B with a XHP35 HI though, have to try it out with my F-8 with zener mod. F-8 has 8 x 7135s and a FET on a 17mm driver board.
OK today I am emailing with Martin about testing of their new 18650 cells
LOL one is now double charging (so with a USB cable direct and a charger. This was kind of exciting to do because Brinytes engineers could not say much more then “don’t do it, maybe the charging circuit fries and burns” so needless to say all progress was followed closely.
But I brought this topic to Martins attention. He is going to forward the information to the engineers, and sure Mike, if you mail him with more details they will consider it very seriously (I mean you just improved an already sweet zoomie so why wouldn’t they )
Yeah, I promised Martin I would send him the link to my first build with impressions, so I’ll do it today even though you have, and suggest a B158C
Yes. I sent an email to an email adress I found on Brynite’s website and asked. I was contacted by Martin, a very good person to deal with. He can be reached at ledflashlight@brinyte.net.
You have done a great job. It has drawed our boss’s attention, I will translate the entire article to my boss and engineers and wait to see whether there will be any change in our future flashlights.
You know we really have a short product line on photography light on land, even we have several photography flashlights for diving, but we really have no such a flashlight which is used in photography on land.
You showed us a direction of how to design our next flashlight. We will take in some of your experience.
I just sent an email with some photos and more detailed explanation of the suggested changes for the host (or new model B158C maybe?). Let us know if it is possible and if there would be a minimum order requirement to make a batch. Others here at BLF might be interested in such hosts or lights.
Yep, the specialized extended pill is the easiest. kiriba-ru is making it for me
This is what I suggested:
Add 8mm of threading to the inner tube, and remove 8mm of the fat part to keep same length on inner tube. Original on top, a crappy photo edit of what I’d like it to look like on the bottom:
For this to work the outer tube has to be 8mm shorter. Original on top, another crappy photo edit on the bottom.
The light will only be 8mm shorter when it’s in full flood. Otherwise length would be the same.
Of coarse maybe Brynite might prefer to make the extended pill and offer it as a separate part for flood extension. Personally I’d rather see changes to the host, would keep weight down a bit, especially if using kiriba-ru’s original copper pill vs extended copper pill, but I’d understand them if they preferred making a new pill instead of a new host.
Ok. I see. I was thinking they would have to extend the Tailcap spring and leave the length the same. If they shortened the body and extended the threads, I agree that would me nice.
I think you are onto something with the extended floody pills. If kiriba-ru makes some, I am in for 2. I have also contacted Brinyte to get my hands on a couple B158B hosts. Your innovation is much appreciated.
Thanks for you suggestion, sir. Our boss has seen this post and this post gave us an inspiration, and we might consider designing flashlights with floodier beam light in the near future.
Cool. I would think that Kiriba-ru would be happy to offer them to others, but that’s for kiriba-ru to announce. I am unable to do a larger buy and then distribute as I’ll be gone for three months starting next week. My pills will be sent to a relative where they will be waiting for my return in November.
I received my B158 host today, and swapped the pill & reverse clicky switch from my B158. First impressions are great. I am definitely a fan of this host. It may even surpass my Jax Z1, which is saying a lot!
It is great to know you have received your light host, it is long journey. Maybe we should have chosen DHL instead. I am eager to see what will happen with your B158B host.
