Haha new avatar! Fitting!
Nice to see your successful triple build. Looking good!
My favourite built light for now…
I want to sell my Palight Boss1 but if I don’t I will build a triple C8 reflector monster of It with three XP-L HI or dedomed XM-L2 and between the three C8 reflector will be an S2+ reflector or a carlco 10507 with triple XP-L for flood. Independent switches for throw and flood.
Ha do not sell that boss1…/serious you cannot sell it now
I seriously need now a lathe :person_facepalming:
Those pre-drilled holes look nice, but then I wouldn’t have much use for my dremel anymore, lol.
Love it!
Will that upgraded switch PCB fit in a S2+ or BLF A6?
Love it!
The diameter is 17mm. I can measure my S2+ tomorrow but I think it will fit too. The A6 I don’t know cause I don’t have that.
Nice build!
I agree it is a must-have (and although I have the parts ready for many months, I do not have it :person_facepalming: )
Most excellent! Is that the Ledil Cute triple lens? Have you thought of sanding it out flat or are you happy with the pattern/output?
Yes Ledil Cute lens. I thougt about polishing but I try to use it this way and if I like it I will leave it that way. I built it one day ago so not used it much.
Love it!
My grey S2+ switch PCB is 16.15mm but it has more room so very tight but it will fit.
congrats…perfect work.i dream about my quad xpl…sadly,too much work i guess:))
Thank you all! More pics and videos coming later. Today I want to make the lighted tailcap for it.
Nice build Zozz. You have built the V6 now for the V8.
And the lighted tailcap is working
I used BLF A17DD driver, and 470 Ohm bleeder resistor on driver and 47KOhm resistors for each pair of the 6 leds in the tailcap. In the tailcap I used PD68s rev5.1 led ring board instead of the stock aluminum washer. This is for the 14mm rubber boot.
The six leds eat 0,106mA so if I use a 3000mA battery it will last for about 19 days.
Is that 0.106ma, or one tenth of a milliamp?
If so, that’s
3000mah / 0.106ma / 24hrs / 365days = 3.23 years
Either way, it looks great!
One tenth of a milliamp. So this way it enough for 3 years?
