Came across those COB work lights on GB a few months ago. I am an automotive enthusiast a have many friends in the repair business. Been giving them (Plastic version) away to buddies and family. Got a few Aluminum ones for myself. So far only one casualty, where it got too hot and melted the lens on a plastic version. Buddy asked whats the waranty? I said I would give him a full refund on his free light. He is 5hour drive from me but I will get him another one on my next visit in a couple weeks.
Snap-on sells a similar light for $30, large auto parts chain sells the same $3 light for $15 around here. Another friend said his paint supplier sells them for $9.
Oh yeah I did have a couple tail magnets come out but CA glue took care of that. I run Eneloops in mine and found one left on inside my backpack. Found it Sunday morning & had not moved the pack since Friday. It was still lit after 2+ days. Not Bright but Lit.
Very practical work light for it’s size. Worth the $3
I have a Nebo Boig Magnum Larry I saw at my local Ace hardware but ordered on Amazon. Great work light. Super strong magnet and wide, smooth, floody beam. Rated at 450 lumens and looks at least that bright to the naked eye. My only complaints are the UI (must click through all modes to off) and visible PWM in the lower mode but under the hood its not an issue. I would like to see a good low mode on it for extended emergency lighting.
I have a friend who is a Heating and A/C tech. He said he and the guys he works with all use a light like this for their work. He likes that it will shine into a small space and light it up evenly, without being too bright. He also likes that he can clip it onto the outside of his shirt pocket, so it will light up a small area directly in front of him for working. I tried to give him something brighter and he said it was too bright for the small spaces he works on. My contest light this year is (very loosely) inspired by this style light. But, it won’t be nearly as shirt-pocket friendly.
I got a bunch of the NEBO COB Lights HERE at LIGHT JUNCTION a while back when they were having a super sale.
40 - 50% off best I remember.
Got several for me and a bunch for gifts. I just find they are handy little lights to have laying around. :+1: …. I run em’ on Eneloops of course.
I received my cob lights (from the link in the OP and in Post 5). They are both nice, but I really like the pen light from the OP. It’s better than I expected. The aluminum body is thick and seems strong. I’m impressed with the amount of light this baby puts out. Very even wide flood as expected. The tint and color rendition is great. The light spreads out so wide and evenly, that you don’t have to worry about glare (Like DavidEF’s friends have said).
The magnet on the clip is fairly strong. The tail magnet is pretty weak. I can really see keeping a few of these in my car. Engine problem at night. Stick one on each side of the hood (by the clip magnets) and you got your self a nicely engine bay.
Don’t know what the run time is like yet. Seems like it may not be long with so much output. Will try to see how hot it gets and how long it runs tonight.
I guess this vendor is selling them at such a low price due to the logo. These go for much more everywhere else I have looked. I had a problem with a third item I purchased (not a light). It was the manufacturers fault. The vendor straighten out the matter on the spot for me with just one private message from me. So I ordered 8 more of these pen lights. Some to keep in my cars and a few for my parents who I know will really like them.
Thanks for this thread hank. I will probably pull one apart when I get the next order, but I doubt I mod it. Might put in more powerful tail magnet. Actually, wouldn’t mind a few modes.
I have the pile of these in plastic and aluminum. got a couple more red aluminum in the other day.
Got a pic of the tail magnet? I think it may be in backward. I do not think any of mine are weak on the tail magnet. and I think in comparison the clip magnet is weak to the tail. Tail magnet has a steel surround or a cup. You should be able to see the steel ring around the edges. If not I would say it’s in backward.
Had important things to be doing so I skipped all that and did this. I will be keeping this one. UMMM, its definitely Brighter.
If you need to get one of these apart just get a fingernail between the side of the lens and aluminum and pop it out. Rest will easily follow. Don’t forget the rubber cap on the SW. You will have to take it apart AGAIN.
Appears mine is backwards then. Thanks for the tip. Also, thanks for the tip on how to break down the light.
So, it appears that the LED has no real heatsink path to the body. Unless there is hidden circuitry in the switch (doubtful), the emitter is direct drive with 1.5 ohm resistor bank in series. There are plenty connections and thin wires that add to the resistance. Hmmm, getting some moddy ideas.
EDIT: Sorry for the multiple edits. Had trouble getting my response out of the quote.
Welcome Sir,
would like to see what you do with it. I didn’t count the LEDs or try to see what the potential voltage of the COB is. Nor try running it and check heat generated. Definitely watch the SW wire in the housing slot, putting it back together. I thought to slip some heatshrink in there but didn’t. Yeah, replace wires too, but didn’t. Certainly could add a strip of aluminum behind the COB, there is room with the spring loading the way its made.
after I got mine apart I could only assume my buddy’s light that melted the lens got shorted. Maybe burned a resistor. But his is also the plastic housing…? I will be in CT tomorrow, visiting. I have his replacement. I’ll dissect his plastic version. Spare parts…
