ENEDED
Is it really a clicky-switch?
Sounds strange with ramping.
But if it really has a clicky (no drain on batteries while off), count me in for two!
/Edit: I forgot, NW please!
I take one NW.
Looks comparable to the Thrunite tn4a hi which I’ve always fancied.
What’s the throw like on this compared to the thrunite? That has a 52340cd rating, I can’t see a figure anywhere for the crelant.
If it’s comparable I’d be interested in a NW.
It should be electronic side switch.Do you still want to be in?
I am interested, at $26 $27 (NW) and depending on review and seller.
Like you’ve said, I’d like to use them as a backup in the glovebox. So it doesn’t make sense to me if it drains the batteries with quietesence current. Could you ask Neal about that point?
/Another edit: or is there some kind of lockout possible?
Good question, I will ask vendor to find standby current drain issue with manufacturer. Other than having a tailcap switch, what other option do we have to address is problem?
V4A is a brand new design, some of it specs have yet to be published. Please give them some time to update them in the coming weeks.
Dear freeme , could you change my order into NW ?
I’m in for one
Anodized threads is the usual way to handle lockout.
1 nuetral white and one clear white, thank you.
It is not that straightforward.
Simple Lock-out Mod for EA4, F40A, etc. - DBSAR
https://budgetlightforum.com/t/-/29694
Nitecore EC4 stand by current drain - texas shooter
https://budgetlightforum.com/t/-/35408
Ok, sounds like banggood is the seller
Please put me in for one neutral white :slight_smile:
Will the bezel be un-glued?
Interested in 1 (NW), thanks!
I’m in for 1 NW, thanks!
I’m in for one
I’m in for one NW. Thanks
One NW please.
Any information on the user interface (single click, double, hold 0.5s, etc) ?
I am in for one CW (unless the UI requires holding > 0.5s to turn on)
(If you don’t stop these group buys, I will have to stop visiting this forum :slight_smile:
