What did you mod today?
Got a Package yesterday from RMM.
Bunch O Shtuff.
Threw together an S2+ grey with FET + 7135 ( MTN17DDm-NUV) guppy dual and spring bypass and XML2 U4 1C.
Light was done before my 1st Coffee this mornin.
2 more S2+ hosts here and some FET triple parts for XPL HI and 219C. But no copper pill to get those done.
Very nice mod, but only 10 nights per charge?
I’ve been using my oldest CNQG brass 18650 light for a night light lately, still with its original XP-G emitter and nanjg driver. But I gave it new firmware. The new “good night” mode blinks out voltage then goes to a ~10 lumen mode and slowly decreases for about an hour until it shuts off and goes into sleep mode. I shut it completely off after waking in the morning. It looks like it’ll last about a year per charge. Would something like that work for you?
I’m not concerned about waking up in the dark though; I mostly just wanted some dim ambient light at bed time so my partner and I can see each other before falling asleep. It’s a bit unfortunate when a goodnight kiss lands on a nose or eye or something. :stuck_out_tongue_winking_eye:
Before that, I was using a ZL SC52 on its brightest moon mode. It gets about 2 months per charge. Not as bright, but still bright enough to see reasonably well (IMO, but I’m super photosensitive).
I guess I’m just a little surprised at the low lumens-per-watt of the amber emitter. It sounds like it’s getting around 25 lm/W?
Today I finally modded my light saber, since the rest of the parts came in. I added a recharge/kill port and a recessed lighted switch.
It was kind of a pain; took a few hours. I had to unsolder parts more than once after messing something up… like when I had it all put together and realized I connected the switch light to the wrong charge port post. Much swearing ensued, since the fix involved working in a very small enclosed space full of thin brittle wires.
Oh, and I also made a fake battery I can plug in and put in a charger, to check or charge the real battery without removing it. Because every time I open the hilt I risk damaging the battery and electronics. It’s weird putting a dummy cell in a charger and having it actually work.
I’ll have to put up pictures later; for now I think it’s time to relax.
You should help them design a more mod friendly module/pill/light engine design and retire to Naboo.
Now you mention that, I re-measured the light and you are correct, I measured it wrong before, I probably did the current reading with the clamp meter at a too high range for these low readings. I now used a DMM at mA current setting:
The second mode is 3.1 lumen, at 16.1 mA. The led would be at 2.8V but the 7135 just burns everything off up to say 4V, so the efficiency OTF is 3.1/(4x0.0161)=48lumen/watt. Still not great because I measured the bare led (link), at 0.2A, at 113 lumen/W, in a flashlight there should be 90lm/W leftover, but times 0.7 caused by the the overvoltage burn-off, so 63lumen/watt. Perhaps at very low amps this led becomes less efficient (or every led? never looked into that actually).
Anyway, runtime suddenly went up to 19 nights of 11 hours :slight_smile:
My brand new mi-7 had been opened up :
Cracking the the threadlock and opening the bezel :
Head disassembling :
Switch assembly :
And now it’s baking at 250°C :
Trying to get a light grey instead of this ugly pinkish red… slowly :
Swapping the CW XP-L HI for a 219C :
JG, At such low current maybe a nimh with a boost driver or liion with a buck driver would be more efficient?
Ideally you are very right. :slight_smile:
In practice, the BLF-A6 driver is what I had and it does the job, there’s not many stock drivers that have a low mode as low as 16mA/3lumen. If there’s a buck driver for single li-ion cells out there that have that nice low mode I’m highly interested :slight_smile: . NiMh batteries will not do it either because whatever the efficiency of the system, for runtime (the light should last for the two weeks camping trip next week) there’s no better option than a high capacity 18650 battery.
technically a repair.
an ancient dorcy 1aaa.
put in one of those 5mm high cri.
it must have a million hours on it.dim sick blue.nearly useless till now.
neighbors kid has had it 10 years.
its the flashlight equivalent of linus’s blanket.
downs syndrome kid.
Okay, I did a write-up for my light saber mod. It’s on another forum though.
Short version: removed the obnoxious stock switch (was an “outie” so I kept bumping it by accident), replaced it with a better one (recessed, has a light inside), and added a charge/kill port so I won’t have to open the hilt unless something inside breaks. And I did a pretty messy job of it all, but it works and the mess is safely hidden inside. :slight_smile:
A large part of the reason for this mod is that the “SaberCore 2” driver board has ridiculously high power draw in standby mode, shown here after turning the blade on then off again:
Most of that 200mA seems to burn off as heat in one chip, which stays too hot to touch unless power is physically disconnected:
I hope the heat won’t be a problem, but I’ve already heard from one person whose driver refuses to boot unless they blow on the hot chip to cool it off. Their thread got removed from the forum by an admin though, which honestly gives me the chills because it’s kind of an important thing to know. I should probably get some thermal transfer cubes and stick one between the hot chip and the aluminum host.
A few pics:
Not actually the layout I followed, but close enough. All I changed was tapping the switch light off the driver’s power source instead of the blade LED. Here’s the actual layout I used:
I accidentally wired this wrong and didn’t realize it until everything was assembled enough to test. Oops. Much swearing ensued, since it’s a huge pain to move a wire after everything is all soldered together.
The switch had a few posts to connect too… and it had to be done with part of the hilt already in place.
On the driver, I only needed to access PWR+, PWR~~, and BAT~~.
Taking out the kill key causes power to be connected, as indicated by the lighted switch: (this switch uses 20ma … super-high current for an accent LED, considering the Kronos X6 tailcap is almost as bright at 0.5mA)
Magic trick and sanity check.
I made a fake battery so I won’t have to remove the real one. Every time I open the hilt, it risks damaging the internals.
But in the end, it works and all is well.
I can finally turn it completely off by putting a little plastic plug in the charge port. And soon I should have some 3D-printed plugs which are low enough profile to leave in during use, and merely need to be rotated to connect or disconnect power. :slight_smile:
It may be just a glorified green flashlight stick, but it’s really fun to play with.
That is ridiculous and so very awesome TK. :open_mouth:
Light sabers were cool in 1977.
In 2016, they're...
still freakin' sweet!
After 2 hours at 250°C, I’ve still not reached a good color, maybe I’ll strip the ano with baking soda to see how it turns…
Brushed steel on the left, polished Ti on the right
Warning: don’t do this (when the wife is) at home. :smiling_imp:
Well, considering the fact that the first time she met me I was using the dishwasher to clean my 125cc carburetor…putting a flashlight in the oven isn’t really annoying for her
Back on April 30th I modified my then brand new Trustfire TR-J20 with 3 of the 9V MT-G2’s, used 35mm Illuminations Machines reflectors and 3 Trustfire 32650’s with 6000mAh and was seeing 13,500 lumens but it would heat up pretty good.
So today I decided to make a heat sink for it and rebuild it…
I decided to add another emitter and make it a quad, using the Ledil Minnie reflector… which is shorter. So I also cut an 8mm thick 78.9mm diameter spacer to sit on top of the emitter shelf (glued it in with Arctic Alumina Thermal Adhesive) and then I used the same adhesive to affix 4 Maxtoch 26mm copper mcpcb’s with 9V MT-G2s on em.
The filled head is now ready to take the heat from 4 MT-G2s and the light weighs in at 3.5 Lbs with no cells in the tube. :slight_smile:
I made an “X” out of copper sheet to solder the positive pads on the mcpcbs to, then soldered an 18 ga lead to the X for power. A longer 18 ga negative lead makes the rounds and is soldered to the negative leads at each stop. :slight_smile:
It was doing a bit over 12,000 lumens with the cells low, they’re on the charger now. I was hoping for 15,000 but don’t know if I’ll get it with that long negative lead, it’s bright though, for sure!
Nice one Dale.
This is kind of a test to see if can post pics from imgur on my phone.
I sometimes hold this little light in my mouth so I cut the end flat and placed a rubber sleeve over it so I don’t grind my teeth.
https://imgur.com/a/vabTR
I don’t have specific emitter voltage from up top, but a tail reading of 22A is coming off the 3 cells, so is that up there in the 268 watt territory? I know the 9V MT-G2 can do a forward voltage up over 11V when pushed hard but I haven’t opened it back up to get top side readings.
The heat sink with thermal paste on it works beautifully, transferring heat all the way down to the battery tube. It takes a little while for the entire head to heat up, but it heats up pretty evenly, something it didn’t do in stock form. They had the lower head section (above the driver) open, empty, nothing but air, and all along that area is heavily finned on the outside. Filling that void with aluminum really makes use of those fins, and with plenty of heat being made it’s a necessary evil.
Can’t believe the 3.5 Lb weight, I didn’t put any copper in this one (save for the 4 MaxToch copper mcpcb’s)
268w is up there. Depends on how much voltage droop you’re getting under load. Still, it’s big Power for 3 cells :crown:
I discovered that my original inside-the-spring 20ga wire bypass on the switch as broken so I did a through board bypass with 18ga wire by modifying the large switch and it’s housing to let the fat wire fit into the tail cap assembly.
Now, with freshly charged Trustfire 32650’s I’m seeing 14,628 lumens out the front. I’m going to have to call that success, being as how it’s a little more than 10,000 lumens more than the stock light was making with it’s 12 XM-L emitters. :wink:
