Now this is interesting, used Heters in the S70 and Liitokala in the L6
The L6 got much warmer and was brighter.
Since the Heters have buttons I have to remember which one was placed head side and swap each charging.
The Liitokala have no button so I use a magnet. Before charging I put the magnet on the other one so the swapping is easy and requires no remembering.
Decided to do the same after checking the ano of the inside of the S70 and seeing it is good.
And now the S70 is brighter then the L6 and not just a tad but really obvious brighter. It also gets warmer then before
These Liitokala cellsist provide more power, nice!
Agreed, it has been stated on here several times that the OPUS gives higher than true readings.
However as long as you always use that same charger for analysing you can still get get an idea of how your cells are.
I already got like 16 of those, they all have the same good quality: a bit better than Efest 4200
For me its the best high amp 26650 battery atm: and overall the best too, the price is lovely also
P.S
A tip: orther them from GB - they somehow manage to ship them safely to EU- all my orders came very fast so far, declared as kitchen goods, ” srom stuff”( dunno what that means , a quote) or just el. components
I also got several Vappower 4200mAh before, they perform lesser than Efest 4200, they are like Keeppower 4200 actualy, good battery but nothing like Li 26650, the last one realy shines with out BLF fet DD drivers
This is good news the Vappower 4200mAh are older and very hard to find in the U.S.; I have used the Keeppower and the Shockli 4200mAh’s and found them to be good too.
There appears to be a new 26650 champ in the 4200mAh category. Tested by Mooch at the ecig forums:
Excerpt from his test report:
“…This is the first 26650 I’ve tested that acts like an 18650. Its internal resistance is lower than many of the good 18650’s and it held its voltage well. At 30A/100W pulsed it ran approximately 75% longer, and 0.15V-0.20V higher, than the Basen and Brillipower 4500mAh cells down to 3.2V. It doesn’t match the appearance of any other 26650 I have so I don’t know where this cell came from…”
Excerpt of a report about my findings on internal resistance for these batteries, published last wednesday 2016/09/07 here (e-cigarette-forum):
0K. Just to let you know I've done some smartass battery IR testing on the sixpack. With a LiitoKala Lii-100 charger (pumping close to 1'05A, maybe ≈1'047A, no lab equipment sorry), my standard multimeter and this mV accurate voltmeter:
Well, the voltmeter drains 10+mA (I think the eBay ad claimed 11mA). All the cells have shown 23ish mV load/no load deltas (measured with the wires under the flat top button, it shouldn't have any significant impact at this current though). The numbers look pretty good, 22-23mΩ of resistance for these cells. Clearly 20A continuous 26650 cells, with 5+Ah of capacity.
Sorry for bumping this thread, but i had ordered the same liitokala 26650 from aliexpress to use in a flashlight.
The thing is that i need to put 4x26650 bateries in serie.
After the fact of ordering and receiving these batteries i read i cannot put them into series?
Or can i with the help of something like?: Assuming a coin wont work?
