Actually, this is clearly superior to the 30Q.
Has HKJ reviewed the HG2 yet?
Similar, but a bit better.
thank you, i did not even know vtc6 even exist. does enerdan have a website so i can purchase these cells?
Thanks for the review HKJ, it’s on my wishlist now
Yes, but by a very small amount. I was mostly noting their similar shaped curves and IR. Comparing the curves, the IR of the 30Q is only about 2% higher than the Sony’s. The Sony does hold a 0.02-0.03V higher voltage throughout the discharge. This is not negligible, but it is a small difference. It equates to approximately 0.2A higher current in a direct drive XPL setup (or even a triple XPL setup).
They do have a website, but they can only sell these cells to companies. Sony do not want these cells in the hand of vapers! Sony probably believe it is bad publicity if a vaper gets the mouth blown away by a Sony branded cell.
Lookout of rewrapped cells without Sony on them.
Note: Enerdan is a German company, i.e. they uses .de, not .com, it is probably also fairly expensive to ship outside Europe.
Wow, very nice… Hope to see them on sale soon. Thanks again HKJ for the review!
Here’s a comparison with the Samsung 30Qs and to what I strongly believe to be rewrapped LG HG2s:
Excellent review, once again! Interesting about the availability, but hopefully it's just a matter of time.
+1
HKJ provides a valuable resource in this ‘Battery Comparator’ link.
Thanks for adding this one to your excellent library of battery reviews.
Sony makes it very clear they don’t want individual cells in the hands of consumers no matter what they use them for. They even say on their spec sheets “these cells are designed to be used in packs. Not for individual use”
Hello!
Do these batteries purport to be any better than LG HG2s a year later? }P
I'd take VTC5s any day.
Cheers ^:)
But HG2 and 30Q are already better than the VTC5…
The reason you see still see so much praise for the VTC5 is because of the vaping community, but their need for very high pulsing current are vastly different to ours…
Of course a matter of opinions. Vaping is not the only high current application, there are others yet, of course, for each battery a freak like me may decide to use to hack/overhaul/repair a tool's pack, more than a thousand may go to vapers' hands.
By the way, I'd love to see a well done review of the A123 systems ANR26650M1A (and or the newer ANR26650M1B) batteries, and see if those can really deliver what they claim to. :???:
Cheers ^:)
I'm not sure, but HKJ's calculated internal resistance of 0.03 for this VTC6 is, I think, the best we've seen? The other top cells, I think, are all 0.04 ohms.
I don't think it's the only important spec, but I find HKJ's internal resistance # the most important spec for DD FET based drivers.
Let’s hope Murata will continue with the Sony quality.
Thanks as always, HKJ.
Thanks for that great review m8, we have a new BLF fed dd king i presume
Yea, might be, but hope we can get them though.
We will Tom, sooner or later we will, have have dozen throwers vaiting for them impatiently
Mooch from reddit , confirmed it can be found also as Enercig EC-C6 . It has Sony VTC6 inside .
