Since Jaxman makes the production model available with XHP50, anyone know if an XHP70 would work in this? Could it be driven hard enough to handle the heat? Or what would be the disadvantage to XHP70 in this?
Took the liberty to pm all those on the original interest list.
Hmm the threading of the zooming part is very nice ans tight, yet comparing the heatpath of a Convoy L6 or TF S70 with t and the Z1 is not designed to take away massive amounts of heat.
The L6 and S70 do get hot so I imagine running a Z1 XHP70 while pushing the emitters very hard could not be the wisest of things to do for a long period of time.
But as most hotrods do not run for extensive periods a XHP70 Z1 gives one a wow factor light and heavy blast for sure and on a lower then hard driven mode I imagine also an useful zoomie. But others may chime in here
Now having trouble making the host parts page work
The ” color ” box doesn’t change when you try to choose
The site is really frustrating Jaxman
Does anybody else get the parts page to work?
It works just fine for me, I just tried it.
Try this link…………
- I see the “parts link” ( Jaxman Parts ) is ‘alive’ again also.
EDIT / As far as the “site being really frustrating”………. maybe it is not the site that is having the “problem”. Personally, it is one of the easiest to use sites I have ever used. I’m not trying to pick on you, but just because you seem to be having a problem please do not automatically blame the site or tell Jaxman about it from the start. Let’s deal with things like this without “drama” or this ‘buy opportunity’ will be a “dead duck” again.
If you want more then one thing
Select it -> add to cart -> continue shopping -> select different part -> and so on.
If you want more of the same item in cart you can set a number.
Not having problems here.
Well except from the occasional switch if language (click “global site” top right corner in that cade)
Still have the same issue using that link
I don’t have any problems with other sites on Ali and had the same issue with the z1 page, I’m certainly not a computer person but the fact that jaxmans z1 pages don’t work or sometimes work if I do a search instead of using the link tells me the Jaxman site is wonky, this is not drama it’s what it is
There may be some old links on there from the first group buy that went belly up if a search is done???
Try this link and see if it works for you??? It works for me……
http://www.aliexpress.com/store/product/Parts-for-JAXMAN-Z1-BLF-Host/1812094_32682213138.html?spm=2114.12010108.1000013.6.XiyFce
I understand that if it does not work for you, that is not drama. But if you are the only person it does not work for then it is highly unlikely the site is “wonky”, as you put it. Otherwise it seems someone else would have the same problem.
Or at least it seems that way to me. YMMV ……
Beachlogger, please see if the links below work for you. I have just checked and they both work fine for me. Hopefully a few others will check them out also.
JAXMAN Z1 Host for BLF
http://www.aliexpress.com/store/product/JAXMAN-Z1-Host-for-BLF/1812094_32676817032.html
Parts for JAXMAN Z1 BLF Host
( Is anyone else having a problem?? )
thanks teacher
The links work for me.
(But I must say AliExpress can do some wonky things like presenting itself in Russian or Spanish all of a sudden )
Still the same issue, I wonder if it’s due to accessing it with an iPad ?
I don’t know?? Could be I guess???
If I had an iPad I’d try it and see if it worked for me but I don’t, I just have a LapTop.??
Maybe if someone reads this that has an iPad they will give it a try and report back.
It’s a mystery to me, something has to be causing it; but I have no idea what.
If you have access to a computer try it and see what happens. That might help verify or rule out the iPad theory.
Hey All, I can verify that the site does not work properly on Safari, Chrome, or Firefox browsers on an iPad. I just duplicated the same issue Beachlogger reported in all three.
Oddly enough, I was having difficulty with a different vendor’s AliExpress page earlier today with Firefox browser on a Mac. I switched to Safari and all was well.
Beachlogger, if you don’t have access to a computer, you can use the AliExpress app from the App Store. Works fine with that.
After installing, search for “Jaxman BLF” to find the item.
Good info goshdogit, thank you for the report. :+1: …
Glad to help! I edited my post above to include info about the AliExpress app working fine on iPad.
I noticed that! Thanks for solving the mystery. :+1: …
Thanks goshdogit, coincidently that’s almost what I said every time I tried to change the “color” box
Argh thanks for solving it guys
Dangit should have asked how you browsed to AliExpress.
BTW my order (host with extension and 3 Nichia 219b LEDs) is shipped the app tells me. The waiting begins!
Fantastic……… Glad it worked Beachlogger.
Arrrgh! Yet 2 more lights that I want! And no $ in the Paypal acc’t at the moment. (I just had to look at the mini C8, I couldn’t have just not clicked on it!)
Thanx for setting this up The Miller!
Ha! :laughing:
Glad you were able to order a host.
Keep us updated on your build!
