And oh yeah about recent zoomies
Got a Jaxman Z1 XML2 NW when it seemed the groupbuy for hosts would fall apart
Love it!
Love it so much I do not want to take it apart so ordered a host with extension tube for another led.
I got a cheapy little Coast hp1 for my dad. It’s the only cheapy zoomie I’ve seen that isn’t terrible to look at. When its zoomed out its got a decent beam pattern with no extra rings of light. It only zooms so far so you never see the shape of the led.
I wish more were like this, using a regular zoomie fully zoomed I always end up backing out just a bit to eliminate the die pattern, just to where the hot spot becomes rounded, this seems to provide better vision as the die pattern disrupts it.
I’ve thought about finding a way to do a mod to resolve this so they don’t quite zoom in all the way.
Lights that use a lens will show the square image of the die when focused, though as mentioned if defocused slightly the square turns into more of a circle. Lights that use a TIR type optic will look more like a reflector beam.
This is one of the mini AA I’m going to get next. But I’m going to try this version, I like it has a knurling pattern on the head instead of just grooves:
Not for many years. The optics are slightly different, with at full zoom the Coasts having a bullseye hotspot (hotspot and spill) and LED Lensers having a hotspot with no spill.
I like mine, feels very solid and high quality. I’m planning on getting an empty pill and fitting a fet driver and dedomed spg2 with springs bypassed just for the hell of it and seeing how far it’ll throw.
Heard that set up is a bit of a monster, albeit with a narrow beam.
I think these lights with larger lens fitted with dedomed XPG2s are best as dedicated throwers. They have narrow beams, but when you are looking 300+m out, the beam is 10+m wide, wide enough IMO to be useful.
