I think your heatsink (is it thermal glue?) is a bit too thick. The top of your carclo sit’s a bit too high for the gap to close on the bezel. Does the carclo slide all the way down? I had to sand off the edges a bit.
Or maybe you can sand down the heatsink. Or the noctigon board a bit, but that is not really nice for the already limited heatsinking maybe.
Or place an (O-)ring to fill the gap.
I don’t know these nichia’s you used. Tint looks nice. Is it bright?
I’m looking to mod a second one with the new noctigon board with the small added pad for a locator led and high cri nichia’s. Someday :person_facepalming:
Worked out nice for you! It’s really my favourite small powerhouse.
Really nice job.
Not bright. I’m like it
It’s warm white led (2500-2700K)
0,01А-0,25А-1,05А - after change SMD resistor R35 for R50
Turbo 2,25А http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15254
i have had one for about 9 months
used normally
last week the switch broke off the circuit board
kind of a bad design
pushing the button strains the 4 solder joints every time you press
be prepared for it to not last forever
i emailed david, the creator, he seems sympathetic but does not offer help
so far
i used to be a fan of this light
but i have had one for about 9 months, normal use, and the switch just broke off the circuit board
this is a weak design
every time you press the button, it stresses 4 tiny solder joints holding the switch on the board
sooner or later it will fatigue and fall off
Wle, that is good to know, on the III version, the switch is body mounted, and mine is still going strong. I use the IV version as a back up anyway.Thanks for the update!
I have a few questions about the DQG 18650 Tiny 4th that I couldn’t find answered anywhere.
1) Is the driver in the light really constant current regulated? That doesn’t seem possible since the driver board seems to lack an inductor (though I can’t find a picture of the bottom of the PCB). At best it seems like it can maintain constant current only as long as the battery voltage stays above Vf using linear regulation or high speed PWM control (though I didn’t see a MCU either). The CNQG page, just says “Current Regulation”. I didn’t see any runtime vs. output graphs anywhere that would shed more light on this.
2) Can it fit protected 18650’s that are ~70mm long?
Same thing happened to mine with only a few weeks of moderate use, bad design the switch could of done with maybe some glue from a heat glue gun or similar behind to hold it rather than reliance on just the 2 solder pins to hold it in place.
shame as I liked it alot
i think it uses 4 solder pads, but still this the WORST design.
all of the force of pressing the button goes to bending it back… it is bound to fail
sorry to say
but i did like it
i bought another one when gearbest had them for $14, has not arrived yet
manker u11 is a better light, just bigger and heavier…
Yeah. My button is too broken today.
it’s like KLS7-TS3606 (3*6*5mm, horizontal) , SWT-11, TS-1135HS-180-003
When I tried to make a FET-modification of the driver.
Button badly soldered. Or it is because of lead-free solder.
I will add one FET transistor in parallel to the one that is responsible for the turbo mode (AOFV). Gate will be on 6th leg of microcontroller.
I could still change the transistors on the board for the best, with less resistance
Does this flashlight have any kind of low voltage notification such as blinking or auto shut off? Trying to understand if non-protected cells are OK or if it’s safer to use protected ones in it.
Is a faulty switch a common issue with this flashlight? I just received mine today. It worked fine the first couple of times, but now it only works sometimes. It either will not turn on or will not turn off or will not switch to a different mode most of the time. Is there an easy fix?
Edit: just found the warning thread related to this issues. I should have done more research before buying this junk.
