ENEDED
1 Nichia 219B and 18650 tube.
Thanks!
I’m in for 2 with 2 18650 tubes
This might be obvious but I am assuming they arent making a heat treated extension tube to match the heat treated version?
How hard is it to heat treat oneself?
… CREE XP-G3 version with a high drain lion must deliver more than 1600 lumen!! (?) …
Interested in 1x Nichia and 1x 18650 extension tube!
+1 K-wong/nichia/18650
Thank you!
Please put me down for One Nichia+18650 Tube+Box
Thanks.
Please one S with 18350 and 18650 Tube ,Nichia-LED´s.
Regards
Jens
1 heat-treated with 18650-tube and XP-G3’s for me, please! :sunglasses:
Forgot to say Cree version for me please…
I’m on the list, the only one with no preference.
Might as well plan on the 18650 tube as well.
+1 Nichia and extension tube
Actually in for 2 Nichia w/ Tubes
I assume that also these are made by Manker? So BG is working with them again?
This must be one heavy light!! And as noted above with the SS stopping the heat, it will have a lot less surface to shed it. Looks good though :slight_smile:
Jos here is something from the OP :
Difference between S41S and S41 aluminium:
Manufactured by new supplier.
New logo.
Missed that :slight_smile: . I will be curious about the ledboard then, it could even have been improved compared to the Manker one :innocent:
I think that they will use led board and driver from Manker . But it’s just a guess , we will see .
I’m interested in a heat treated Nichia 219b version with 18650 tube (assuming the 18650 tube is also heat treated). If the 18650 tube isn’t available with heat treating I don’t want heat treating on the S41S.
Freeme , if you can , correct my leds to xp-g3 , on the next list update (that’s my first choice :slight_smile: ) .
1 - Nichia + 18650 tube + heat treatment.
Tjohn
  • With the overall bias towards selecting Nichias so far in this ‘Feeler’, and considering the obvious enthusiasm for the pair of Jaxman HiCri Nichia offerings in 4000k and 5700k, substituting the Cree with the cooler Nichia, or at least testing the audience by questioning their preference could be very interesting. Even better, imagine the audacity of including a 219C in the mix.
    A clever manufacturer could perform a comprehensive market test of 4 Nichia options, with or without the Cree if they wanted to in a ‘Feeler’, settling on the most popular for eventual ‘general’ distribution.
NuggetMcNugget, Nichia 219B + 18650 extension
