ENEDED
Please one S with 18350 and 18650 Tube ,Nichia-LED´s.
Regards
Jens
1 heat-treated with 18650-tube and XP-G3’s for me, please! :sunglasses:
Forgot to say Cree version for me please…
I’m on the list, the only one with no preference.
Might as well plan on the 18650 tube as well.
+1 Nichia and extension tube
Actually in for 2 Nichia w/ Tubes
I assume that also these are made by Manker? So BG is working with them again?
This must be one heavy light!! And as noted above with the SS stopping the heat, it will have a lot less surface to shed it. Looks good though :slight_smile:
Jos here is something from the OP :
Difference between S41S and S41 aluminium:
Manufactured by new supplier.
New logo.
Missed that :slight_smile: . I will be curious about the ledboard then, it could even have been improved compared to the Manker one :innocent:
I think that they will use led board and driver from Manker . But it’s just a guess , we will see .
I’m interested in a heat treated Nichia 219b version with 18650 tube (assuming the 18650 tube is also heat treated). If the 18650 tube isn’t available with heat treating I don’t want heat treating on the S41S.
Freeme , if you can , correct my leds to xp-g3 , on the next list update (that’s my first choice :slight_smile: ) .
1 - Nichia + 18650 tube + heat treatment.
Tjohn
  • With the overall bias towards selecting Nichias so far in this ‘Feeler’, and considering the obvious enthusiasm for the pair of Jaxman HiCri Nichia offerings in 4000k and 5700k, substituting the Cree with the cooler Nichia, or at least testing the audience by questioning their preference could be very interesting. Even better, imagine the audacity of including a 219C in the mix.
    A clever manufacturer could perform a comprehensive market test of 4 Nichia options, with or without the Cree if they wanted to in a ‘Feeler’, settling on the most popular for eventual ‘general’ distribution.
NuggetMcNugget, Nichia 219B + 18650 extension
In for one nichia.
Yes 219C 83CRI would be nice.
And XP-G3 NW would be nice, too.
Now, with the standard S41, there is only the choice between low lumen with high CRI in NW tint or high lumen with low cri and CW.
If that should happen, there must be the combination of higher CRI with not too less lumen, that means 219C and Higher Lumen in NW, that means XP-G3 NW or XP-L HI NW.
Wasn’t the major concern with the S41 the LED layout on the MCPCB? Is this one still going to have the positive end of the emitters on the outside with nothing but some masking to keep the screws from shorting out?
Interested in 1 Nichia
Thanks
1x heat treatment - Nichia +*18650 tube( only if the heat treated 18650 tube is available )
means 2*S41S Nichia with 2*18650 tubes altogether!
sorry for my mistakable wording :facepalm:
In for one S41S with Cree XP-G3 and 18650 tube , thanks. PS. thinking about another one heat treated……hmmm…
Friend extension tube 18650 ty
