Thanks for the review. :+1: I had no idea this even existed. Can it use normal IMR high amp 18650’s? Or is there some majic box in that proprietary Nitecore 18650?
That battery has some weird circuitry that the light recognizes. It won’t go into the two high modes without the battery made especially for this light.
great video as always. can you please measure if the strobe is the same output as turbo? a 3000 lumen strobe must be wicked in a light this size. im expecting it will probably be only 1200 lumens on strobe….
Now who knows if the light meter reads it correctly…. I’m getting pulses from about 370 lumens to 468 lumens. It’s hard to do an apples to apples- because strobes seem brighter to your eyes, but looking at it on a white wall it definitely isn’t anywhere near full power. It looks brighter than it really may be.
I use a black magic pocket cinema camera for most stuff, and a Panasonic g7 for supplemental footage. They both share a common lens mount, and I use a combination of c-mount, 35mm manual still lenses, and a few modern micro 4/3 lenses.
I shoot my night stuff with lenses with an f-stop as low as a 1.4 and I have one video light that I can dial in a color temperature. Then I color correct my footage slightly to make everything match and adjust levels in post for over and under exposed stuff.
Thank you for testing this. I wonder why they couldn’t or didn’t make the strobe at full power? If it’s a tactical light with the secondary switch for instant strobe, the buyer may purposely buy the light because of this feature, and would indeed like a 3000 lumens pocket sized light.
Thanks for the in-depth review, I had to go ahead and get one of these as I just couldn’t resist… boost or not.
Had to laugh when you were trying to spark the cell when installing it, my luck will probably let me do it when I’m NOT trying to. hahaha I purchased a back-up cell, just in case. A bit pricey but not bad for a proprietary. Beats the price of a Canon DSLR battery pack, that’s for sure!
So much about this light is intriguing, from the deep reflector to the boost circuit, the lever action on the tail, they’re really creating new boundaries over at Nitecore and I just had to see for myself with a hands on… thanks for the guide and all the pertinents.
I was able to get it to spark, when I wasn’t recording. Trust me- it does! I feel the deep reflector way have been a missed opportunity… if outfitted with a better throwing emitter or made smooth. I’m finishing up my Acebeam K70 review, and that dedomed XHP35 HI would have been pretty cool, driven hard in this light. And yes… way cheaper than a Canon battery. Thanks!
Anyone want to know more about the “proprietary” cell? The expensive Nitecore TM-03 battery that is “high drain” and “high capacity”?
I bought a back-up directly from the “NitecoreStore”. It came in today, before the light made it. And who’d a thunk what I found inside? A simple little ol Panasonic PF! That’s right, with circuitry top and bottom making it proprietary! Figure I’ll take the circuitry off and attach it to a Samsung 30Q and see what happens.
