It was asked to me by PM too by someone . It was a 100x gree-to-blue mix very leisure tossed loose in a small grip-bag by ebay-seller ledbaron. But the listing is gone now, and it appears that cyan 0603 or 0805 leds can’t be found on ebay anymore (or anywhere else?). Green, blue and ice-blue are easily found though, i.e. at lebaron (german seller).
So far the most I have ever used is 3 LED’s. For my next one I think I will use all 6 pads. I just can’t decide if I want to mix red and blue, or blue and green, or red and yellow.
I’d suggest to build three in the above colors.
Fwiw Kaidomain has several different sized translucent tail caps including 8, 10, 13.6, 14, and 16mm.
I am in a similar LED delima myself.
Firstly, has anyone ordered LED’s from digikey? Any recommendations?
I am thinking I will grab these in a few colors to start out with, they have the highest MCD rating for the price/size so I figure they should net more light at low currents as well.
Next is color, I am thinking I would focus on green or blue/green combo as they should be the brightest for the least amount of power used since our eveys are more sensitive to those colors. Or is red just too good looking to pass up?
On the newer boards the power is so infinitesimal, just go with what color you want. Having said that, you could look at it from the angle that reds and oranges have a lower Vf, so they need less power to be as bright as the greens
I suppose so, I just tend to overthinks things to make sure I get the best possible setup, even on the little things.
Test it! Perceived brightness vs power draw at different input voltages
Oh I plan to, just like to know I have all the parts I would need ahead of time. I royally hate having to wait for parts in order to finish a project.
Then just get several values to start with.
Yeah, I am going to order some of each color.
No big deal, was just curious on peoples opinions for color and experience with LED models.
Every time this thread gets some attention, I start thinking about something I’d like to change. This time it’s to incorporate the header pins I got to use with the TripleStack.
So here is what I dub Rev5.3, Top and Bottom. The two boards are aligned so you can use header pins to connect them through the vias.
Top has Six LEDs, two channels, and two resistors for balancing colors. It also has a jumper pads to merge the two channels to bypass the resistors.
Bottom should be very familiar: two pots and the mini slide-switch to jump between them.
That feeling when you buy something and the very next day new updated version is released:
Lol sorry. If you actually ordered yesterday you can cancel as long as they haven’t been sent to fab yet.
There weren’t really any features added other than the pins anyways, so I wouldn’t feel too bad
They were assigned to panel in about 20 minutes from my payment and sent to fab. in less than a hour.
No speed limits for OSH park
What switch can i use best for the 20mm rev4 ? I want to use them in a solarforce l2p tail, it has big square switch original.
Most of these are designed for the Omten 1288. Others may fit but you’ll just have to try it. The BIG SWITCH version might be best. It will be added to the OP soon.
I am currently editing the OP over the course of the day, so don’t be alarmed if parts are missing.
Jumpers on the top ring are a great addition. For single-color tailcaps I’ve been relying on the pot’s resistance and just jumping all of the resistor pads together with a piece of copper braid, but had to be careful with the placement so it still stacked flush. A thin solder connect over such a small jumper will be much thinner. Thanks!
Ok I think I’m done with the OP for now. I tried to organize and simplify……. I think it ended up longer than before. :person_facepalming:
Oh well, at least there shouldn’t be any more dead product links.
Yes, it is much better laid out now and much more understandable. Good job!
