18 september update
Category coupon for full priced product ( except some special products ) flashlight http://www.gearbest.com/led-flashlights-c_11265/
price: 12% off discount - coupon: LIG12OFF
1.Nitenumen NE01 Updated VER LED Flashlight - UPDATED VERSION
● CREE XP-L V5 LED, maximum output up to 1060 Lumens
● 7 modes: turbo; high; mid; low; moonlight; strobe; SOS
● Lock-out function prevents accidental activation
● Built-in Micro USB charging port, intelligent Li-ion battery charging circuit
● User-friendly red and blue battery indicator, low-voltage warning
● IPX-8 waterproof standard ( 2m ), let alone rainy days
● Aviation aluminum vacuum electroplating reflector offers 236M far beam
● Intelligent constant current driver circuit ensures constant output
● Precise temperature control system adjusts output according automatically
● 320h ultra long runtime, compatible with 18650, 16340 and CR123A batteries ( not included )
2. WUBEN E346 300LM CREE XP-G2 LED Flashlight
● Perfect for home use, camping, hiking, searching, trekking, hunting, fishing, car emergency, etc.
● CREE XP-G2 LED gives out super bright and stable light beam with low energy consumption
● Two lighting modes ( low, high ) are suitable for different occasions
● Special appearance design, wear-resisting, impact resistant and scratch-resistant
● IPX8 waterproof function allows you to use it in any weather
● Made of aluminum alloy, durable to use and sturdy in hand
● Twist the head to turn on the light and adjust the brightness
● You can charge the battery rapidly by any devices with a USB port, such as computer, desktop, laptop, power bank
● The key ring for easy carrying
● Powered by 1 x 16340 800mAh battery ( included )
● Impact resistant to 1.5M
● Lightweight, compact and small size
● After fully charged, it can be used for 1.2H at high brightness and for 11.5H for low brightness
● Light source: CREE XP-G2
3. WUBEN I333 1200LM CREE XPL-V5 LED Flashlight
● CREE XPL-V5 LED gives out super bright and stable light beam with low energy consumption
● Seven lighting modes ( moon, low, middle, high, super bright, strobe, SOS ) are suitable for different occasions
● Lotus head can smash the glass easily, which can help you to escape as in emergency
● With the power indicator function, you can know the battery power clearly ( when button W is blue, the battery power is more than 30pct. When button W is red, the battery power is more among 30 - 10pct. When button W is red with flicker, the battery power is less than 10pct )
● The switch is on the tail of the light, convenient to use by one hand
● With the clasp, easy to hang in outdoor bag and jeans
● The rope for easy carrying
● Powered by 1 x 18650 2600mAh battery ( included )
4. Manker E11 Mini LED Flashlight - 1A 6500K
●Brand: Manker
●Model: E11
●Lamp Beads: Cree XP-L
●Beads Number: 1
●Lumens Range: 500-1000Lumens
●Luminous Flux: 800 (14500) / 400Lm (AA)
●Color Temperature: 6500K (1A) / 5000K (3D)
●Switch Type: Clicky
●Switch Location: Side Switch
●Feature: Cooling Slot of High Efficiency,Lanyard,Lightweight,Pocket Clip
●Function: Camping,EDC,Hiking,Household Use,Night Riding,Walking
●Battery Type: 14500,AA
●Battery Quantity: 1 x AA / 14500 battery (not included)
●Mode: 4Mode (High > Middle > Low > Lower)
●Mode Memory: Yes
●Waterproof Standard: IPX-8 Standard Waterproof
