I tested both of mine vs both my fluke and UT139C multimeters (they agree on basically everything).
The power supplies agreed with my multimeters to within the stated tolerances. Generally no more then .01 off or so except in the super fine voltage regain.
I can run an actual official test if people want it. After running them through the voltage range while connected to my multimeters in both current and voltage mode I decided that I didn’t need to do anymore testing.
At any given point the power supplies were generally not off by more then .01. A few spots they were slightly further off but still within spec from my back of the hand math as I ran through the numbers.
The only “inaccuracy” I noted was that when making super fine voltage adjustments it would sometimes “miss” a change. I would not expect them to reliably adjust voltage more accurate then .01 at a time, trying to adjust in smaller increments it will still show the correct voltage it is outputting but it may not be exactly what you set it for.
For what I do with these and what most of us here would use them for this is already far more accuracy then we need for LED’s.
Honestly the larger inaccuracy comes from cheap test leads / banana plugs. I was getting up to .1v of voltage drop per amp with cheap leads and banana plugs. Upgrading to 14 gauge wire dropped it to around .08v per amp. Using better banana plugs/connectors dropped it down further to around .055v per amp.
Finally I connected it with an XT60 connector, this nets me around .03v of voltage drop per amp. This is about as good as you can get with 14g wire. Direct connecting it was around .25v per amp drop.
I tried some larger 12 gauge wire as a test and it dropped it a bit further but it also was harder to work with so think I am going to stick to 12 gauge. I did make up some 4 gauge leads but I need an XT60 connector to plug them in.
For high current work good test leads are key and this is not an issue with the power supply itself, simply an issue with dealing with higher currents.
Also an example of why all the OEM flashlights are in series battery config, higher voltage is easy compared to high amperage.
LOL, you’re promoting these ‘budget’ power items but you have a fluke! I have one of those cheap and nasty yellow DMM’s. I had 2 but the battery went flat in one and when I replaced the battery it still didn’t work. It took a few minutes to work out the + and - terminals had been labelled incorrectly :rage:
I think TA is more just alerting us to what he feels is a good deal for decent equipment that is being sold by it’s own designer. Hopefully, that means the price is low, but the equipment is not cheap. Plus it should have better customer support with trouble shooting and such.
Order place for a 5015. Still not sure what I what I will power it with yet.
Not totally sure what a fluke multimeter has to do with a power supply? They are completely different devices. The power supply outputs power, the fluke multimeter reads how much it is outputting.
FYI, I picked up my flukes for $10 each from a garage sale (well I had another one from a pawn shop for $18 but I sold that one to pay for the rest, so I actually ended up with the ones I kept for free lol).
That said I actually prefer my UT139C over the flukes unless I am dealing with really high voltage (like over 220v mains), over that and the fluke does have better protection. Under that the UT139C is more accurate, more features and easier to use IMO. The price is great for a nice multimeter, think I paid around $35 for mine.
The funny thing is that I still end up using my harbor fright free multimeters the most. They are simple, quick and I don’t care about them. So I generally just grab one of those (calibrated with my other ones so it is actually quite accurate) and do what I need to do. Only when I need precision or features do I grab the UT139C.
Exactly, I have no connection with these power supplies other then having talked to the designer a few times about possible future features.
After having searched high and low for an adjustable power supply that would handle the high currents that LED’s need and finding nothing in the sub $50 range, I figured there might be others in my shoes.
Having used these for a month or 2 and them working flawlessly I figured they had proved themselves to me enough to let some others know about them.
I was not sure what I would do with them besides using them to test LED’s at first but since I got them I keep finding more and more uses for them. It is nice for testing all sorts of electronics. Also nice for electroplating, making colloidal silver, anodizing among other things I could not do before.
In our case, if you get the 5015 you can use it as a 15 amp (with a fan blowing over it) capable battery charger (obviously you would want a few batteries in parallel if charging at full current). I use it for fast charging sometimes although my B6 works fine for that as well if I just put 2 cells on it.
It is nice for battery recovery as well, if you have really discharged cells you want to hit them with really low currents (under 50-100ma per cell) till around 3.5V, then slowly increase the current from there. This is much easier to control with a power supply them my charger at low currents.
They are, a lot of people would put the deal I got under the category of a “steal”. The guy I got them from knew it was just that as well but I was buying a bunch of other stuff from him at the same time and by buying these he got to close up shop early in the 100+ degree temps, so he cut me a deal.
If I was to resell these I could get about $50-60 for them, which is what I got for the other one I sold. The new models are several hundred bucks each and honestly unless I was a professional dealing with voltages well over 240v on a regular basis, I would not buy them.
The Uni-T 139C is more then enough for everyone else. It is another item I highly recommend for the budget electronics tinkering BTW. A cheap multimeter (aka, harbor freight or other sub $20 meter) works just fine if it is calibrated, the issue is you never know if it actually is calibrated correctly or not. I got the 139C to remove that doubt as the reviews online are overwhelmingly positive, even from those super picking about multimeters). The extra features are a nice bonus and the extra digit is surprisingly useful.
I ordered the 5015. Now I am starting to plan the housing. You mentioned that good banana sockets lowered resistance. How do you know what plugs are “good”? There are so many chiices and prices. It seems the good ones are mixed into a wide array of cheap ones.
Yes, the banana jacks/plugs I had were the cheap ones from ebay and they sucked. Voltage drop of over .05v per amp in those alone.
I swapped to an XT60 hobby connector for my main leads now and just have a pair of banana jacks in case I need a unique connector.
I personally never got a good banana jack but I only tried 2 different kinds. I am guessing it is a matter of you get what you pay for.
Going with your main leads with an XT60 style jack or just directly connected is the best option, then have a secondary pair of cheap banana jacks for other stuff. I find that if I need the banana jacks it generally doesn’t need much current and as such the voltage drop is not a big deal.
A bit slow to report here as hobby time has been limited. I received my 5015 last week. Packed crazy well in a rectangular Styrofoam cooler type container. Components and assembly appear to be high quality to my amateur eyes. Super easy to set up as all the connection points are well labeled. Haven't got around to making an enclosure. So just did a couple quick tests to make sure it works. Seems to work really well. Voltage and current see rock steady and easy to control. Very happy so far. Need to hook up an oscilloscope after I finish the power supply, but my sense is it in a totally different league than the benchtop psu in the bottom picture.
They are both buck converters and work similar. It is basically a matter of quality and output level.
The one on banggood is a lot harder to work with and I am going to guess not as accurate.
The LCD screen on the 5015 is an amazing tool that makes using it far more plesent.
The biggest difference though is the 5015 is good for 50v and 15A, the one on banggood is only good for 36V and 6A.
If you don’t need more then that, then they will both do the job. Although they also have cheaper dp and dps options if you don’t need as much current.
Higher current requires much better components and design.
Yeah, that would work just fine. I have that model as well myself and it works great. That said the firmware is nicer on the DPS series but nothing that major.
Yeah, it was posted in my review but the above quote is the gist of it.
That is one thing I forgot to mention, the larger 3012 and 5015 allow you to charge batteries without a diode, which is much much better (it allows you to see the actual voltage of the batteries instead of just what the supply is putting out plus the diodes have a voltage drop as we know.
The ability to charge batteries with up to 15A is quite a nice feature to have.
You can look at the extra cost as a high powered battery charger.
So, I am considering ordering the DPS 5015. I have never used AliExpress. Do you guys preload a card to use with them? If so, what kind of card does it take?
They are secure enough that I just use my normal card. I mean aliexpress / alibaba is one of the largest companies in the world, I am gonna guess that they have halfway decent security.
I did not buy one of these, however I have in the past been greatly disappointed with these type of supplies due to my overly exuberant expectations.
Don’t expect to input 40V and have continuously variable output voltage from 0V to 32V AND be able to draw 12A along that whole range.
I am guessing here, but I’m thinking that you could possibly get that 12A only IF the input voltage is no more than say 1.5 times the output voltage.
Even that 12A might be an exaggeration.
For me, this could be useful for some portable power. Mate this with an 18V drill pack, and you could do all kinds of neat things with it.
