The Monster TK61
43 posts / 0 new
LSX
LSX's picture
Last seen: 5 hours 9 min ago
The Monster TK61
Update – 02/27/2019
So it’s been about 2.5 years since I started this thread and I haven’t been very active around here for a while! Life has taken priority with buying a house, getting married and going on a long trip to the US for our honeymoon.
However, I decided to pull my finger out and get this build going again. The sad part is though, by today’s standards this light isn’t going to be overly impressive anymore! Crying
Anyway here is today’s update:
I modeled the heatsink/spacer in Rhino
I then took the CAD file and my chunk of aluminium to the machine shop and this is the result:
A few more things which have happened:
- I’ve decided to purchase two BLF GT 4S battery carriers from Neal rather than modifying the factory ones as I think I will end up with a better result this way, it will be cleaner and should carry more current.
- I have purchased some more 16AWG Teflon wire and think I will go with blue and transparent now
That’s it for now and hopefully the next post won’t take another 2.5 years!
Original Post – 30/08/2016
Well, I have been collecting a few parts recently and the last of them arrived today.
They say a picture says a thousand words so I will just leave these here for now…
Edited by: LSX on 02/27/2019 - 05:27
LSX
LSX's picture
Reserved
LSX
LSX's picture
Reserved
pinkpanda3310
pinkpanda3310's picture
Last seen: 9 hours 2 min ago
Xpl hi ??
LSX
LSX's picture
Yeah, 24x XP-L HI V2 3A
pinkpanda3310
Definitely a monster. Looking forward to it Cool
zeremefico
zeremefico's picture
Last seen: 4 hours 26 min ago
WOW
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
tru3s1lv3r
tru3s1lv3r's picture
So are you gonna have to register that thing with the CASA? That’s gotta be like 20k+ lumens! Amazing and I’m excited to see how it all turns out.
Aspiring Fhashlightaholic!
MRsDNF
MRsDNF's picture
Last seen: 5 hours 28 min ago
Where will this insanity end? Smile
LSX
LSX's picture
I’m actually a little nervous myself!! haha
I have bought some 16awg silver plated teflon wire from the US which I’m hoping will carry the current ok.
Twin FET set up so the firmware controls both FETs and they run at predetermined %‘s and the second switch will control the third driver which is there only as a lockout.
RAW74
RAW74's picture
Last seen: 10 months 3 weeks ago
You’ll shoot your eye out! Wink
Nicolicous
Nicolicous's picture
Last seen: 18 min 44 sec ago
Cash
damn
you can start a bushfire with that monster Smile
Nico -.-
Flashy Mike
Flashy Mike's picture
Last seen: 14 min 57 sec ago
You’ll need a high speed camera for the beamshots …
LSX
LSX's picture
I’m just hoping the whole thing doesn’t melt down! Looking forward to getting in to the build, but don’t think I will have too much time coming up.
Turningbluechips
Turningbluechips's picture
Last seen: 9 months 3 weeks ago
Holy crap, no that won’t do… HOLY CRAP!!!
Just the thought of it makes my eyes hurt. Pure awesomeness.
pilotdog68
pilotdog68's picture
Last seen: 3 months 6 days ago
Are those Carclo optics? Dale recently found you get a lot more (apparent) light out of Khatod optics. Something to think about before you cut down your heatsink.
LSX
LSX's picture
They are Carclo, that’s interesting to hear. Where is the best place to get the Khatod optics? Are they still 24mm dia?
LSX
LSX's picture
Haha thanks! I’ve got a bit of work ahead of me!
pilotdog68
All I really know is what is in Dale’s OP here: http://budgetlightforum.com/node/46854
I think they are a little bigger than 24mm, so they might not fit? They fit the cutter Tpads though.
DB Custom
DB Custom's picture
Last seen: 23 hours 16 min ago
The Khatod’s are available at Cutter and the Cutter quad mcpcb is designed to accept them, it’s the reason for the slot instead of a hole for the legs. Wink
Tighter beam, more output. Taller optic as well so the heat sink will be shorter.
Edit: Might be worthy to note I had a bit of issue with the Khatod quad over XP-L HI emitters. I had the HI’s in my little DBC-04 Titanium light and one of them got the bond wire broken by the very small opening of the TIR on the Khatod. I now have 219C’s in it and they’re working fine. Also might make note that when I built a Quad X6 with XP-L HI’s I ended up with less lumens than a 219C variant due to the lower Vf of the 219C. Something to think about anyway.
DB Custom
DB Custom's picture
Curious, you gonna leave the cells in 8.4V configuration and run Zener modified FET’s to the quad board with the LED’s in 2S2P configuration?
Edit: Are you aware that you can take the battery carrier’s apart and replace the narrow gauge brass rod that carries ground with an 18ga Turnigy wire for better current? Spring bypasses are a must. Wink
freeme
freeme's picture
Last seen: 8 hours 19 min ago
LSX
LSX's picture
Already ahead of you on that one Dale. I actually have a third carrier I have already started working on. I’m converting them both to 4S so will end up with 4S2P. All traces are being beefed up with 3mm braid with solder in it, springs have been bypassed and the little domes they use for the positive contact have been replaced with solid brass buttons. I’m also replacing the ground rods and hopefully will be able to use the 16AWG Teflon wire I got.
sesgum
sesgum's picture
Last seen: 8 hours 22 min ago
This guy must be crazy! Smile
Can’t wait to see the monster alive!
MRsDNF
MRsDNF's picture
Its the water out West that makes them different. Wink
pinkpanda3310
No idea what you’re talking about ???
EasyB
Last seen: 7 hours 55 min ago
The openings on the khatod optic are indeed very small. I wonder if a lot more light is lost (not collected by the optic) when the larger XPL HI is used.
LSX
LSX's picture
It sounds as though I might be safer just using the Carclo optics. I don’t want to have problems with the emitters in this light. They cost a small fortune!
Cula
Cula's picture
Last seen: 5 hours 24 min ago
Can’t wait to see how this monster comes to life, please hurry with the build Smile .
LSX
LSX's picture
KawiBoy1428
KawiBoy1428's picture
Last seen: 3 hours 6 min ago
Nice job! Thumbs Up
KB1428 “Live Life WOT
