The 4th Annual BLF / O-L Contest; MtnDon's Entry, Hand Made Class
Alright. It looks like it is finished. Unless I implement a mod!
I tore it down, cleaned up the mug shell a little and took some more photos as I finished details and reassembled.
I added a spacer to the bottom of the lower module insert. This was cut from a piece of scrap walnut and fixed in place with some 3M double sided tape. The tape has a little give and will squish down when the module is secured with screws.
Pacman is gonna eat the switch…
I drilled out the mount holes and glued in some aluminum threaded inserts. I couldn’t find machine screws long enough to use a nut so took this route. Looks nicer anyhow I think.
A view of the bottom plate that is glued to the mug bottom. The center hole was used as a positioning guide and is now filled with a section of dowel, glued in. The switch boot is from one of those cheapy zoom lights. The holes with the recess will be used to secure the lower module inside the mug. The other two holes were temporary holes used in determining where / how to mount the lower module. I’ll fill them with a couple short lengths of dowel but was out of an appropriate size.
Next we have the LED and MCPCB mounted to the aluminum block. The star was filed flat and heat transfer compound was used.
A view of the heat sink mounted to the lid. The machine screws go through to the aluminum block. The unfilled outer holes will be used in assembling the upper module.
The lower module insert being secured with machine screws through the bottom. I used a length of dowel rod to help hold the assembly. Stainless steel 6-32 machine screws.
There it is with the lower module secured.
A view looking down inside the mug… lower module secured in place.
Another view…
Here’s the upper plate. Driver mounted to one side and the cell contact top springs on the other side. (not visible here). The threaded aluminum posts will be used to connect the two halves of the upper module.
Here we have the other side of that piece with the springs barely visible. The brass tube is the + lead from the cells to the driver.
Upper module assembled with more spacers, tube section plus fine tuning washers.
The 22 gauge wires were trimmed and soldered to the MCPCB
The test fitting of the remote phosphor dome. Two small notches were made to clear the spacer posts and another two notches to clear the LED wires. I used a hot soldering iron tip.
The completed upper module in the correct orientation…
Kind of a difficult shot with glare on the mug. This one shows the upper module half being inserted The brass tube of the upper must be inserted into the lower brass tube.
There! Success; upper tube inside lower tube… To properly fit the upper module the colors of the wood used for the two halves must be matched. I use the walnut segment as my guide. The “handmadeness” is revealed by the slightly different spacing of the cell holes around the circumference.
Next we can see when the contact springs are just barely touching the cell ends there is approximately a 1/4” gap between the lid and the rim of the mug. This can be adjusted by removing or installing washers between the aluminum spacer posts of the upper module. This will permit changing to a longer cell at anytime in the future. The lower surface of the lid has a rubber sealing ring. That combined with the heat transfer compound used between the heat sink and the lid should make it safe to have at least light rain fall on the light.
The insert assembly is pushed down and the band tightened to secure the lid.
All set to go now !!!
It does light and moves upwards through the 6 levels of, 2% 6% 15% 25% 50% 100% with 100% being 1.4 amps.
I’ll do some dark room shots when I can
Cool!
Very nice. A toast to the light. :beer:
Illumination… on low; 2%
Tonight I’ll try some dark room shots with the camera on manual settings. I haven’t pursued beam shots yet so some experimentation will be required. I complicated things by leaving the tripod out of town…
Bring it on winter.
A very unique LED lantern design!
Very very nice. :+1:
Light / brightness shots. These are harder to do than one might think. Our eyes are too darn accomodating in changing what we can see in different levels of light. If the first picture is a more or less accurate rendition of how the light illuminates on level 6, the highest level using 1.4 amps then the depicted brightness of level 3 (15% or 210 mA) or level 4 (25% or 350 mA) are not bright enough.
For the record my 70 year old eyes have no problem reading normal book size print on level 3 210 mA). Level 4 is better, but in the space I was using level 5 (50% or 700 mA) is not needed.
Level 1 (28 mA) is of limited use I suppose, but thows enough light to keep me from tripping over the chair by the door way.
Anyhow, FWIW, here we go from highest level down. What the camera recorded….
First level 6 (bright, 1.4 amps)
level 5, 700 mA
level 4, 350 mA
level 3, 210 mA
level 2, 85 mA
level one, 28 mA
On level 1 my eyes can still make out the counters and items on them. So it’s not as dark as the camera makes it to appear.
I think I am going to get myself a meter, something like the LX1330B. Then I can at least make some measurements and see some figures I can maybe relate to better.
Of course that will mean another project… an integrating sphere of some kind in order to add to the usefulness and add meaning to the numbers. :slight_smile:
With the camera looking at the light it tends to see the light instead of the subject. It might be more accurate to shoot with the light offset behind the camera so the camera reads the subject instead. I’m not big on beam shots anyway since, as you say, they can be misleading. It works and has the right number of modes. Well done sir!
The camera was on manual and the ISO was NOT on auto.
Maybe I’ll try repeating the set of images but move the lantern out of the frame as suggested. I like it. Makes me really want to find a polycarbonate mug instead of the acrylic. I actually did find a couple of sellers of polycarbonate jar top 16 ounce mugs. But the minimum order quantity is 24 mugs; $68 plus shipping. I don’t need 24….
I must thank DBSAR for inspiration. It was his lantern project with the downfire LED that helped me formulate this plan. The vessel, well that was purely from my own weird thoughts.
I do find the phosphor dome illumination to be pleasant. The dome does not have that annoying pin prick effect that many commercially made lanterns have. I do prefer lights in the 4500 –5000 K range over the warmer tones. I’m different that way. So this suits me fine. The phosphors are available in some warmer temperatures but in smaller cone / elliptical shapes. This dome was easy to fit over a standard LED star. A cone shaped phosphor with a diameter of around 15 mm and smaller would make for a more difficult mount. Just another challenge though!
I am thinking about incorporating a micro LED voltmeter, but space is a bit tight inside the mug. … thinking cap is still on…. I think it would be cool to be able to monitor the battery voltage without having to access the cells. Maybe a momentary contact switch to activate for the reading? But I also don’t want to make it more difficult to access the cells. Easy changing of the cells was a prime goal of mine. And switches mean perforations and more wires……
Just use a driver with a batt check feature as one of the modes.
I love your unusual design.
By micro LED Voltmeter, are you thinking of one of these ? Perhaps you could simply set it up so that the battery voltage is always displayed when the light is on. The listing claims it uses less than 30ma, but I will measure one tonight. It seems like you could mortise the meter into the battery block without too much trouble.
I had and lost a couple of these meters, ordered a 10 pack to replace them, and promptly found the lost ones once the new ones came in. PM me your address and I’ll send you one if you would like.
Yes that is the meter type. It may be possible to mortise one into the cell block. Would be cool. With a very low draw having it only on with the light on would likely be hardly noticeable. Thanks for the offer.
Looks great, Don. Did you leave any room in the mug for some beer? :wink:
That would be different to the normal water cooled. :stuck_out_tongue:
:laughing: They make double walled mugs. The space between the two walls is supposed to be insulation. I had the crazy idea that it would be cool to use that space to hold the beverage and have the light works inside as I have done. Some kind of a “sippy cup” mouthpiece feature for drinking from would need to be implemented / invented. :person_facepalming:
