Probably was, there aren’t any reviews out there for the 5015, and only a couple for the smaller units. Found a pretty good YouTube review for one of the smaller ones.
As far as the dual input V input you suggested, a different option, that might be easier to implement, would be to have a fine adjustment pot for the voltage output. That way you could wire up any type of leads you want, and adjust the voltage until it matched what you actually have at the cable ends. That would work for a lot of different wire sizes and leads, because everyone’s is going to be different in a project like this where you have to make your own. And for those that don’t want to, or aren’t comfortable with adjusting it, it could simply be set to read at the unit from the factory, that way it’s essentially be unchanged from how it works now. But it’d be a great benefit for those who are comfortable tweaking it a little.
Does that sound like something that would work or that could be implemented by the manufacturer?
about DPS5015, there is only some test video on youtube - YouTube . but there is video to make real power supply to use DPS3012 Самодельный лабораторный блок питания. - YouTube
you can see .
about your plane to use a meter and some DC-DC power module to make power supply . I cam say it is hard to make a better one . I know there are some video for this power supply on youtube ,. but some are too simple , some are less function…
our DPS power supply is very cheap to get those powerful function…
if you want to my DPS power supply , you can get the discount .
