Review of DP50V5A & DPS3012 bench top power supply modules, best bang for the buck around!
Hi,
when I look in detail these 2 products, I think only the 1st one is capable of constant current (mandatory to drive LEDs), I can see 2 potentiometers to adjust output voltage and current.
The second one has only 1 potentiemeter to adjust output voltage.
Do you confirm my understanding ?
Thanks
Yes, that first converter appears to have the correct specs and should work, although I have no experience with them. I would mount it to a heat sink of some sort as it looks like it will get hot with high outputs.
Other then that though, it should work well based on the specs.
With a dual voltage input, it would make a great internal resistance mearuring tool as well.
I just bought this enclosure. Hope it’s not too big?
It should work great, just make sure you get a 5V fan and install it somewhere blowing over the board along with exhaust holes as well. You can tap the fan into the existing fan output.
Does the module control the fan or will it run steady?
It controls the fan, which is why I like to tap into it. It only kicks it on when it gets hot or when outputting above ~6 amps. It also appears to be PWM as it blows harder the hotter it gets.
Oh. Great!
I imagine you could run a duct to the existing fan if you don’t want to add a separate fan. Just a tube going from the fan to the opposing side with vent holes to let the air get pushed out/drawn in.
You could but the existing fan is undersized for extended periods at high amps IMHO. The Shunts could also use some cooling as well which the stock fan does not do.
Now electronics can work fine at higher temps, I just don’t like them to be hotter then needed.
Looking at your pictures in Post 2, I get a sense for what your saying. That stock fan is so tiny. Good info. Thanks.
Yep, it seems to keep the mosfets reasonably cool for the 5-10 mins I have tested it at max amps but doesn’t do anything for the rest of the board.
You will note that I placed the vents next to the shunts in order to ensure the airflow goes over them.
This is really cool, way past well enough done for the job. I'll just point out though that there is something called acrylic glue. It's rated for something like 2000 lbs per square inch too if used well. Not to criticize. Mine will look worse. I'll probably end up taping it to a shoe box and leaving it that way for 10 years.
Yeah, I knew there was glue for the job and I actually really wanted to make it screw together but I was in a hurry and didn’t feel like waiting for special glue lol.
No to mention that the hot glue is removable if I really wanted to and since I was not sure at the time how it would work in this, I wanted to be able to take it back apart if needed.
Do you disconnect the small fan or run them both together?
I just spliced the new one into it, they both turn on.
K. Thanks:)
Texas_Ace how I can contact you ? I need your help . email or what'sapp? my email is 1749808860@qq.com or whatsapp account +8615868157353
I just sent you an email to the above email address.
Replying to random old post... I doubt this is PWM. Looks like only two wires. PWM fans use 4. I believe it's 2 for power, 1 for PWM and 1 to signal rate back to the controller. However, as I recall there are motherboard fan controllers capable of just ramping voltage. I'm 99% sure that's true for 3 pin fans (that report their speed but don't take PWM) but I can't remember if any do it for 2 pin fans.That doesn't mean it couldn't be or isn't being done though. However different fans have different minimal operating voltages and it might not come on as soon as desired. Not to worry, the board should keep getting hotter until it ramps up the voltage more and it does eventually come on.
A fairly common trick (and I sometimes use it) is to wire two-wire fans between the 12V and 5V lines of a CPU PSU, running it at 7V instead 12, making it much less noisy, and in some cases still providing the desired flow, especially for extra case vent fans, hard drive fans, places where super insane speed really isn't ever needed.
