Small sun ZY-T08 mod II - The Next Generation
Thanks djozz for your kind words, I’m especially proud of this one. It was the hardest one I made so far.
That one should be in the Old-Lumens Hand built challenge, you’ve got plenty of documentation in photo’s, give the a shout out and see if you can add it in…
How does the beam compare to your JM30?
I’m really quite jealous. I can make some bright lights, but they’ll never be as finished and beautiful as this
Thanks Dale, I learned a great deal of things about LED’s and Flashlights reading trough your posts and builds :beer: .
Don’t know if I can qualify since this is production flashlight.
It is far more brighter and smoother, the tint is also to my taste. Something between moderate thrower and powerful flooder but no hotspot in the distance. It is a bigger and deeper reflector then that one in JM30 which is quite shallow. JM30 is a pure flooder.
The polish job on the copper alone is incredible! WOW! :beer:
Did some beamshots, they are crappy ones taken from a cell phone. Sorry but I couldn’t do any better ones with this camera.
1. Control picture - distance around 70 meters
2. High (9 Amps)
3. Control picture - distance around 25 meters
4. High (9 Amps)
I’ll do some Head/cooling fins temperature measurements tomorrow and post the results.
Wooow just Wooow i imagine the time taken just to redesign this flashlight, nicely done, you made me really wanting to remod mine, also i haven’t seen an awesome modding like this in a while and yes as you said Next Generation :+1:
Incredible!
Great work.
Sorry, but of course it doesn’t qualify because it’s a production flashlight, but I got so caught up in how drastically you changed it I lost track of the small details of the scratch build thread. lol
:open_mouth: Beautiful work Cula!!!
Orsm mod. I’m looking forward to seeing this on the big screen when l get home.
Nice!!!
Looks beautiful! Very neat work, and apparently with minimal tools. I would have assumed that a mill was necessary. And all that mirror polish and smooth paint is on the inside.
Wow! Justin once tried to interest the forum in a contest to mod an existing light… This would have been a slam dunk winner.
Very VERY nice, all those details!
Awesome beamshots (and some nice trees you see there)
Maybe some sort of modding contest could be organised to follow up the build from scratch contest (though we already have a winner :smiley: )
great work . do you have a link to the reflector you are using
Thanks guys for your comments :+1: :beer: .
Of course.
http://www.kaidomain.com/p/S021809.55_5mm(D)-x-32mm(H)-OP-Aluminum-Reflector
Emitter hole is only 8mm. You need to make it wider to fit the XHP-70. Also the base is flat so you have to grind enough aluminum so that it doesn’t shorten the led wires. Luckily, there is enough “meat” to grind, it is pretty thick at the bottom.
Do you have a picture of your dremel setup? You do great work and yet it looks like you do not have any extravagant equipment.
He says “dremel” but also says it’s a milling bit (end mill?) mounted in a drill press which the picture shows, looks like it could be a Bosch.
