Small sun ZY-T08 mod II - The Next Generation
How does the beam compare to your JM30?
I’m really quite jealous. I can make some bright lights, but they’ll never be as finished and beautiful as this
Thanks Dale, I learned a great deal of things about LED’s and Flashlights reading trough your posts and builds :beer: .
Don’t know if I can qualify since this is production flashlight.
It is far more brighter and smoother, the tint is also to my taste. Something between moderate thrower and powerful flooder but no hotspot in the distance. It is a bigger and deeper reflector then that one in JM30 which is quite shallow. JM30 is a pure flooder.
The polish job on the copper alone is incredible! WOW! :beer:
Did some beamshots, they are crappy ones taken from a cell phone. Sorry but I couldn’t do any better ones with this camera.
1. Control picture - distance around 70 meters
2. High (9 Amps)
3. Control picture - distance around 25 meters
4. High (9 Amps)
I’ll do some Head/cooling fins temperature measurements tomorrow and post the results.
Wooow just Wooow i imagine the time taken just to redesign this flashlight, nicely done, you made me really wanting to remod mine, also i haven’t seen an awesome modding like this in a while and yes as you said Next Generation :+1:
Incredible!
Great work.
Sorry, but of course it doesn’t qualify because it’s a production flashlight, but I got so caught up in how drastically you changed it I lost track of the small details of the scratch build thread. lol
:open_mouth: Beautiful work Cula!!!
Orsm mod. I’m looking forward to seeing this on the big screen when l get home.
Nice!!!
Looks beautiful! Very neat work, and apparently with minimal tools. I would have assumed that a mill was necessary. And all that mirror polish and smooth paint is on the inside.
Wow! Justin once tried to interest the forum in a contest to mod an existing light… This would have been a slam dunk winner.
Very VERY nice, all those details!
Awesome beamshots (and some nice trees you see there)
Maybe some sort of modding contest could be organised to follow up the build from scratch contest (though we already have a winner :smiley: )
great work . do you have a link to the reflector you are using
Thanks guys for your comments :+1: :beer: .
Of course.
http://www.kaidomain.com/p/S021809.55_5mm(D)-x-32mm(H)-OP-Aluminum-Reflector
Emitter hole is only 8mm. You need to make it wider to fit the XHP-70. Also the base is flat so you have to grind enough aluminum so that it doesn’t shorten the led wires. Luckily, there is enough “meat” to grind, it is pretty thick at the bottom.
Do you have a picture of your dremel setup? You do great work and yet it looks like you do not have any extravagant equipment.
He says “dremel” but also says it’s a milling bit (end mill?) mounted in a drill press which the picture shows, looks like it could be a Bosch.
Very very nice&big job, well done!
I have thinked many and many time to pull the trigger on the Small sun ZY-T08 because it is a very nice torch and I like so much the form factory…but I’m not able to do anything you doit so well :person_facepalming:
May can I ask you a little more of work? When you can/if you can, do you can make a small video? A coupple of minutes will be enough, because on Youtube the Smallsun is missing (only a very short&poor video) to show the power&beauty of this light. Thanx again! :+1:
Maybe my English isn’t so good and it looks confusing so I apologize for that. Electric tools used in all my builds are bench drill, simple dremel tool which you can buy for $20 and bench grinder. I buy affordable drill bits (like the one in picture No. 30) mainly from Banggood and use them for drilling, grinding and dremeling. Rest is done using hand tools like all kinds of hand files, scissors for metal etc. As you can see these are all common hobby tools that every average workshop have. Wish I had a lathe, things would be much simpler but I don’t have a place for it. It is a small workshop in my basement.
Yes, it is a Bosch, my workhorse.
Drill bits used for my builds:
